runnin 93 in the 0540
sprayn&prayn
Post by sprayn&prayn »
Hi,
I recently bought a boat with an 0540 and it is my first lycoming, but the guy I bought it from said he had the motor set up with lower compression in it so he could run pump gas threw it apparantly. He told me not to run av gas in it but I was told that after every 5 tanks or so to fill it up from dead empty with av gas and run it. Any input would be greatly appreciated, thank you.
Re: runnin 93 in the 0540
Post by John Fenner »
(Popcorn Smily here)
Running the lower compression will give it some longevity, but the inevitable cracked exhaust port problems will still show up eventually, might as well not bother with running a tank of 100ll as the lead is not in there for the valve seats as they are hardened anyway. When you come off of a long or hard run dont shut it right down let it run at idle for a bit to cool off.
A cooling shroud may help it stay cooler as well.
JAMES
Post by JAMES »
ONE OF THE BADDEST 540'S N OUR MARSH IS A PUMP GAS SPECIAL :D I DONT SEE HOW AV GAS WOULD HURT ANYTHING .. HELL EVEN CAR MOTORS RUN THAT STANK SHYT :wink:
yobee
Post by yobee »
Use lead additive or at least mix it with av gas. The lead will help the valves.
dusty burch
Post by dusty burch »
low compression or not aircraft engine needs av gas it was made for that
getitdone
Post by getitdone »
at a minimum i would run 50/50 mix 93 and avgas. i use only avgas in my new motor but did run mix in old one which is still running.
"Poachers Dream"
13'x7'6" Hamant Ultralight With 0540 And 72"Q
sprayn&prayn
Thanks.. much appreciated!
