O-290-G Flange
rbjscott
O-290-G Flange
Post by rbjscott »
I am looking any information on flange strengthening of an O-290-G. Any info. Would be appreciated
"The price of Freedom is high! And the sound of Freedom is loud!" (Jet fighter pilot)
chugalug
Re: O-290-G Flange
Post by chugalug »
If the bend is on the flange only,you can take a pipe wrench and a piece of pipe and probably straighten that way. I would weld a backup flange on the rear of flange, being it is thin.
rbjscott
Re: O-290-G Flange
Post by rbjscott »
The flange is straight.What does the back up flange look like? I assume two half circles?
JT540
Re: O-290-G Flange
Post by JT540 »
you are right its two half circles that are cut to fit then tig welded, before you weld make sure to bolt the flange to something thick an flat to minimize warping. tig it up the machine it back flat. and bore youre holes for dowels only.
rbjscott
Re: O-290-G Flange
Post by rbjscott »
W@hat welding wire do you use.
techelp3215436655
Re: O-290-G Flange
Post by techelp3215436655 »
Alumitech Inc can replace your bent/warped flanges call 407-423-3431 free tec8668075354 airboatdave@gmail.com
JT540
Re: O-290-G Flange
Post by JT540 »
for that part of the flange you can use a standard steel tig rod. i would not try to mig weld it. if you putting a new flange on it take a special rod. but just adding a stiffiner you can use regular rod.
