Chrome or steel cylinder ?
Steve hart
Postby Steve hart » Sun Jul 29, 2012 8:26 am
How do you tell if you have chrome or steel cylinders? Are the cylinders actuly sleeved? Do I have to remove the cylinders to determine this?
JAMES
Re: Chrome or steel cylinder ?
Postby JAMES » Sun Jul 29, 2012 8:50 am
if u have a flash light pull a plug u will see that the chrome shin and the steel wont if their old old cylinders chrome will still dull out and pit as well u may have to pull it off !!
rjonesboy
Postby rjonesboy » Sun Jul 29, 2012 9:08 am
Look into the spark plug holes as described with a light. The chrome cylinders will look like they have a million little cracks in them. Also, some chrome cylinders were painted orange at the bases, where they bolt up to the case.
AirHog
Postby AirHog » Sun Jul 29, 2012 10:46 am
Just remember, chrome cylinders use steel rings, Steel cylinders use chrome rings.
If you change a cylinder from chrome to steel, or steel to chrome, you have to change rings.
Good Luck!
rbjscott
Postby rbjscott » Sun Jul 29, 2012 1:16 pm
Why can't you run steel on steel ?
"The price of Freedom is high! And the sound of Freedom is loud!" (Jet fighter pilot)
todd glover
Postby todd glover » Sun Jul 29, 2012 1:53 pm
You can but they would have to be tool steel or plasma moly car rings for example better off just using ac rings
JAMES
Postby JAMES » Sun Jul 29, 2012 6:20 pm
rjonesboy wrote:Look into the spark plug holes as described with a light. The chrome cylinders will look like they have a million little cracks in them. Also, some chrome cylinders were painted orange at the bases, where they bolt up to the case.
broken glass sorta speak !!
