Cooling Shroud Pictures please!!!
hunter12
Post by hunter12 »
I'm adding this thread to extend the info on the previous thread incase some people dont look at it and read this.
Please post pictures of your cowl's or cooling shrouds for us to look at!! There seems to be a handful of us that want to try to build em!! Thank you!!
LIL Maddog
Re: Cooling Shroud Pictures please!!!
Post by LIL Maddog »
This is the best picture i have of mine of it finished. I'll take some more tonight or tomorrow and post them up. Image
LIL Maddog
Little George Palm Beach "kit hull". IO-540 with a 1.73:1 Stinger gearbox swinging an 81" 3 blade NGR. Real quiet.
Proud Member of USFTH!
cowtown
Post by cowtown »
not sure how to pull from my gallery on SA , but there is some pics in there !!!
http://usfth.tripod.com
And Proud Of It !!!
rhodes
Post by rhodes »
go to Heat Extractor.com for pics &info
Whitebear
Post by Whitebear »
rhodes wrote:go to Heat Extractor.com for pics &info
Forbidden
You don't have permission to access / on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Is there another part to that address??
bman
Post by bman »
Whitebear
Post by Whitebear »
SWEET ! ! !
woolybgr
Post by woolybgr »
does anyone know if they make a cooling shroud for a 0540 upstack?
Cutler
Post by Cutler »
How about a 220 gpu, I know it would be difficult with all the intake / carb configurations
cowtown
Post by cowtown »
Cutler wrote:How about a 220 gpu, I know it would be difficult with all the intake / carb configurations
Cutler , look in my gallery , it not hard to make , there is one on a GPU in my gallery !!
And Proud Of It !!!
Thunder200
Post by Thunder200 »
just my opinion but those heat extractors remind me of putting tin foil around a boston butt?? anyone have any real data of the before and after temps on thier motors?? Just wondering?? Just looks like to me it would keep the heat held around the motor. I understand it on an airplane but the motor is in front and the air is forced through it. not so much on an airboat. Just wondering???
Cutler
Post by Cutler »
Thanks cowtown, I saw them and it give me a better idea of what I can do
LIL Maddog
gyrocopter582 wrote:Alright! The lightbulb has been turned ON!
Lets see who else will pull their head out of the sand!
The problem I see with the designs shown,
there is too much area above the cylinders,
it should fit tighter, about an inch above the head fins.
Plus it should not be open on the end opposite the prop.
It should wrap around and turn down around the front cylinders.
It should extend aft very close to the prop, with a flare .
The idea is to pull air up from the bottom,
then over the top and out towards the prop.
There is an incredible suction available for cooling.
Gyro: My shroud comes 1/2-3/4 of the way down the front of the cylinders opposite the prop and is right up against them to draw air upward through the fins. And above it is as low as it could be with the fuel injection spider on top of the case. Also the gaps between the cylinders are closed in to draw more air through the fins. You will be able to see this when i take more pictures.
LIL Maddog
Post by Deano »
RAJ84 wrote:just my opinion but those heat extractors remind me of putting tin foil around a boston butt?? anyone have any real data of the before and after temps on thier motors?? . . .
Yes, there is plenty of real life data. Use the search function and you will find a bunch.
Look at it this way, In order the cooling fins to do their job, they need to have airflow going between them.
By nature of an airboat application, the movement of air is going across the top of the valve covers and out the prop, the radical bulk of it is not moving between the fins on the jugs.
It is very much like turning your radiator so that the air was hitting the end of it instead of going throught it.
You can easily see that woud not work very well. Running an a/c engine without a shroud is a similar senario, just not as extreme.
With the shroud properly designed, like Gyro eluded to and Parker has shown, the movement of air is redirected (or pulled) up between the jugs and through the fins and THEN through the prop. The difference in volume of cool air over the jugs makes the temperature difference readily measurable.
ptr34
Post by ptr34 »
tons videos on YouTube ptr34
LIL Maddog
gyrocopter582 wrote: and disregard what yer "uncle" ran...
I know you are fairly new to this gyro but you sir have the right idea. That is the problem with so many people that run airboats and a few manufacturers IMO. They wont try anything new and if it isn't what has always been done then it wont work. I find it rather comical personally. Hope to meet you at the FAA ride.
LIL Maddog
LIL Maddog
Dang well hopefully you'll be able to make it to the next event.
hunter12
Post by hunter12 »
Lil Maddog, I like the looks of your shroud on your motor, thats about what I was visualizing in my head to try to try to build... Nice being able to see it! I appreciate the post!
hunter12
Post by hunter12 »
What is the best way to connect the cooling shroud to the motor so it doesn't come off without wanting to take it off???
hunter12
Post by hunter12 »
Cuz if the shroud gets loose or comes off I foresee shrapnel flying everywhere like a grenade went off..
GeeLeDouche
Post by GeeLeDouche »
Heres a quick picture of mine on my 0-470 L. it isnt pretty but it sure works like a charm!
gator7272
Post by gator7272 »
This is damn sure not purdy, but effective so far, Still gotta work on skirts down around the valve covers....
11.5 X 7.5 Alumitech
2.0 Ecotec LTG
2.38:1 Ballistic
3 Blade Whirlwind 2.0
gator7272
Post by gator7272 »
GeeLeDouche wrote:Heres a quick picture of mine on my 0-470 L. it isnt pretty but it sure works like a charm!
Gee, is that your rear running light right near your mag? FWC would get a real kick out of that, not raggin' ya by any means, but I can see em' swormin' upon you down here.....
I personally have a 4" band of flexible leds wrapped around my vertical support on my cage, and they frown upon that, but it's legal, it's just that if they see something they haven't seen before, they think auotmatic ticket$$$$$$, lmao
2.0 Ecotec LTG
2.38:1 Ballistic
flash
Post by flash »
Them GW's need to get a life,,, are there no real bandits for them to chase anymore and their just BORED?
.....actually a very nice shroud Geele,,, did you loc-tite the valve cover screws holding it.
Gun control is not about Guns, it's about CONTROL!
USMC---ALWAYS FAITHFUL
'Those who would sacrifice liberty for safety deserve neither' ...ol BEN
nunook
Post by nunook »
Made a template out of door skin. then laid it flat on the sheet metal and traced it then bent it. Work great.
2006 Floral City 14' Deckover Lycoming GSO-480
