JETTING A 500 HOLLEY GPU
GMAC 76
Postby GMAC 76 » Mon Dec 10, 2012 2:37 pm
need some advice on jetting a 500 holley on a 220 gpu ,dual mags & high comp pistons.......current jets are #76's engine seems to be running rich (according to the spark plugs) wondering how far to go without getting to lean only jets i have on hand are 74,71 & 69's was hoping someone may have some first hand experience with this setup and could help me out.........running autolite 386 gapped at .024
PeaRiverOpossum
Re: JETTING A 500 HOLLEY GPU
Postby PeaRiverOpossum » Mon Dec 10, 2012 2:49 pm
I was going through this same exact thing when I rebuilt mine. I searched on here and called everyone that I could think of and was told 74-76 jets. I just ordered a jet kit from summit and played around with them. I think I ended up using 76s. The kit is around $20 and would be a good investment vs. buying them individually. I am anxious to hear what others have to say. You may need to go with hotter plugs or re-gap...just guessing :dontknow: FYI....I think mine had 67s in it when I got it.
Postby John Fenner » Mon Dec 10, 2012 3:25 pm
They typically come with 73 jets, get a power valve plug and block it off, you dont need it, I have 73s in my 220/470 convo.
PeaRiverOpossum
Postby PeaRiverOpossum » Mon Dec 10, 2012 3:37 pm
John Fenner wrote:They typically come with 73 jets, get a power valve plug and block it off, you dont need it, I have 73s in my 220/470 convo.
John can you please give us a brief description on what the power valve actually does or doesn't do in this case?
Sent from my DROID RAZR using Tapatalk 2
josh_2562
Postby josh_2562 » Mon Dec 10, 2012 3:40 pm
What power valve are y'all running? If I remember right the auto lite are a black plug :scratch: when I tuned my gpu I used champion d16's they were easier to see the color on. It's been a few years but I think I used #76's
I got a holly 500 on a 0520 and I know it has #77 jets in it. Stock power valve
PeaRiverOpossum
Postby PeaRiverOpossum » Mon Dec 10, 2012 4:07 pm
josh_2562 wrote:What power valve are y'all running? If I remember right the auto lite are a black plug :scratch: when I tuned my gpu I used champion d16's they were easier to see the color on. It's been a few years but I think I used #76's
it has been a while since I fooled with it but it seems like I'm running a 6.5 power valve
JAMES
Postby JAMES » Mon Dec 10, 2012 7:18 pm
INCREASE JETS BY 2 SZ AT A TIME I RAN 78'S N MINE AND A 10.0 OR 10.5PV WHAT EVER IT IS AND RAN GET GET A BIG SQUIRTER 35+ GOOD LUCK DONT BLOCK THE POWER VALVE ITS THEIR FOR A REASON !!
Postby John Fenner » Mon Dec 10, 2012 11:20 pm
The power valve adds about 10% extra fuel under hard accelleration in a pickup truck application, towing or a hill run. Not needed in our application. You can easily bolt on a new two bbl 500 cfm carb and never have a problem running a GPU and a convo.the Cfm is comparable.
Users browsing this forum: No registered users and 20 guests
