Engine runs rough in cold weather
CAPTAIN-D
Post by CAPTAIN-D » Tue Dec 25, 2012 3:01 pm
Anyone run heat from the headers or muffler to the ventura on the carb to keep the moisture from freezing up and causing the engine to run rough in cold weather? If so I would like to see how it was done.Thanks.
twister69z
Re: Engine runs rough in cold weather
Post by twister69z » Tue Dec 25, 2012 7:57 pm
http://www.southernairboat.com/phpBB3/v ... &view=next
Here is a previous discussion on it, should be easy to do , construct a aluminum shroud around the exhaust system and plumb a piece of scat tubing to the carburetor air cleaner housing.
Twister69z
lbdb1a
Post by lbdb1a » Tue Dec 25, 2012 10:30 pm
Take a look at what i did with 12 volt heat pads.
Larry
http://www.southernairboat.com/phpBB3/v ... 85&t=46512
CAPTAIN-D
Post by CAPTAIN-D » Wed Dec 26, 2012 12:27 pm
Thanks,I just ordered the heating pads.Looks like a easy way to solve this problem.
GeeLeDouche
Post by GeeLeDouche » Fri Dec 28, 2012 2:10 am
Most of us AV motor guys here in Utah run those hot air exchangers from the headers to the carb. i think they work great.
