Electronic ignition
tom-tom 863
Electronic ignition
Post by tom-tom 863 »
What is the best most reliable electronic ignition to run and what is the price range for a 4 cylinder? Any input is appreciated! Thanks.
Currently boatless but not for long
billybob
Re: Electronic ignition
Post by billybob »
Get ahold of Abner at Keeners machine down south.
I do all my own stunts!!!!!!
farmboy
Post by farmboy »
X2 on Abner at Keeners machine shop in west palm beach. He sells Electromotive (XDI). on a 6 cylinder mine was $1600 and to me well worth it. If you do the ignition I would put the map sensor on it as well its probably a little more but works well. (561)686-6134 Keeners
tom-tom 863
farmboy wrote:X2 on Abner at Keeners machine shop in west palm beach. He sells Electromotive (XDI). on a 6 cylinder mine was $1600 and to me well worth it. If you do the ignition I would put the map sensor on it as well its probably a little more but works well. (561)686-6134 Keeners
Farmboy, what is it about electronic ignition that makes it worth while to you?
Bruce
Post by Bruce »
based on what ive seen with it id hold out for awhile til all the bugs are worked out esp on a ride boat i see too many people have issues with it jmo
12 foot Mamba "The Underdog"
todd glover
Post by todd glover »
I can't see it what willing gain maybe a hotter spark that doesn't do much and more accurate timing I know with mags it fluctuates +- 2 degrees I've seen that I just not sure what you gain I have external coils 50k volts thats almost 3'times hotter than 1200 series mags now what it has done is not lose more than 50 rpm with 1 mag off but I'm not an expert by any means I just try different things but 1600$ I Want to see 100-200 rpm increase jmo
farmboy
Post by farmboy »
I've got 95hours on my boat... 50mag hours & 45electronic ignition hours. In the 45 electronic ignition hours my boat has ran smoother on a idle,smoother up an running, more responsive, and better on fuel. In my opinion just more efficient and went to a colder spark plug. Now I'm not saying my mags where exactly timed to a tee but a aircraft motor builder put them on and timed it.... Everybody has there opinions about the ignition but you can ask anyone that's rode,drove or been around my boat will tell ya it runs damm good with it. People say what if the battery goes dead what are you gonna do ? Well it wouldn't matter you sure cant hand prop 9 blades on a geared 480 so what would it matter? And 9 times out of 10 there's other boats around. There's good and bad with anything it's just what works for you.
cowtown
Post by cowtown »
farmboy wrote:I've got 95hours on my boat... 50mag hours & 45electronic ignition hours. In the 45 electronic ignition hours my boat has ran smoother on a idle,smoother up an running, more responsive, and better on fuel. In my opinion just more efficient and went to a colder spark plug. Now I'm not saying my mags where exactly timed to a tee but a aircraft motor builder put them on and timed it.... Everybody has there opinions about the ignition but you can ask anyone that's rode,drove or been around my boat will tell ya it runs damm good with it. People say what if the battery goes dead what are you gonna do ? Well it wouldn't matter you sure cant hand prop 9 blades on a geared 480 so what would it matter? And 9 times out of 10 there's other boats around. There's good and bad with anything it's just what works for you.
not trying to be a smart butt , but you can hand prop your motor , I have done mine with the ten blade, just depends on how bad them skeeters are , or how bad you wanna leave.
http://usfth.tripod.com
And Proud Of It !!!
farmboy
Post by farmboy »
Cowtown I guess your right it does depend on if your out of beer and how bad the bugs are :lol: I would be the first to say there's NO way I would !
cowtown
Post by cowtown »
farmboy wrote:Cowtown I guess your right it does depend on if your out of beer and how bad the bugs are :lol: I would be the first to say there's NO way I would !
the skeeter were the size of turkeys , every time they hit , they pulled a pint a blood , had to go , lol , didnt like doing it , but the starter wasnt working ,
And Proud Of It !!!
farmboy
Post by farmboy »
Lmao :lol: I hear ya on that !
HAMMERHEAD
Post by HAMMERHEAD »
YOU CAN HAVE YOUR BUDDY GIVE YOU A JUMPSTART THEN PULL THE CABLES OFF AND DRIVE BACK TO THE HILL THOUGH, OR RIDE FOR THE REST OF THE DAY AND GET A JUMP EVERY TIME YOU NEED TO GET IT STARTED. OR WITH THE DSI YOU CAN GET PULLED BACK TO THE HILL AND GO HOME. JUST SAYIN!
tom-tom 863
HAMMERHEAD wrote:YOU CAN HAVE YOUR BUDDY GIVE YOU A JUMPSTART THEN PULL THE CABLES OFF AND DRIVE BACK TO THE HILL THOUGH, OR RIDE FOR THE REST OF THE DAY AND GET A JUMP EVERY TIME YOU NEED TO GET IT STARTED. OR WITH THE DSI YOU CAN GET PULLED BACK TO THE HILL AND GO HOME. JUST SAYIN!
This may be a dumb question but what is DSI?
HAMMERHEAD
DIS IS PROBABLY NOT THE BEST TERM FOR AN AIRBOAT APP. BUT ITS THE ELECTRONIC IGNITION SYSTEM. IM NOT SURE WHERE GARY ARMSTRONG IS LOCATED BUT HE SELLS THE SYSTEM AS WELL AND IS A SUPER NICE GUY, I THINK HE GOES BY GKA540 ON HERE. I HAD 2 CASES OF DISLEXIA!
Post by John Fenner »
DIS, if you are running nitromethane it works well, but you aren't going to hand prop it1.5 revolutions to start it. Mags are simple.
scottymartin
Post by scottymartin »
:thumbleft:
X2 for Gary Armstrong, GKA540..Knows his stuff..and can think out of the box :scratch:
He does the electronic ignition and loves it... fair in pricing as well. :)
Little Bear 12' Scorpion w / O-360 200hp
Bubba
Post by Bubba »
Gary is the man!!!
FLIRTIN WITH DISASTER
GKA 0540
Post by GKA 0540 »
Hey Thomas, i sent you a p.m. The kit i use comes from Keeners, i sent you thier number, Abner and I are neighbors and do alot of these together. call me if i can help you with anything, Gary (561)722-8444
tom-tom 863
Thanks man will do!
Marshandmarine
Post by Marshandmarine »
i have installed lots of elctroair kits witch is the same thing a elctromotive, the ECU'S are the same the only differnce is the sticker on the box.. the only other differnce is on the crank sensor, elctomotive uses a sensor the goes on the block that picks up on the fly wheel witch some air crafts engines are done the same way but on the 4 cylnd. i like the mag style pick up it works really well..
tom-tom 863
I've heard that electroair isn't as good as electromotive. Not sure why this is just what I've heard.
Marshandmarine
Ive worked with elctromotive on quite a few jobs ive done, the ecu's is made by electromotive and some of the mag pickups were made by electroair when you get the elctroair kit there is a elctromotive manual in the elctroair kit.. there is really no price difference in the two i would order the elctroair kit simply b.c you will get every thing you need in one order. elctroair has nothing to do with the mag pick up design how ever it is still there crank sensor that goes in the mag pick up. also when they are installed on aircraft they are only allowed to run one set of plugs on the electronic ignition so when ordering make sure you tell them you will be using two coil packs and not one
Marshandmarine
electromotive has nothing to do with the mag style pick ups** sorry about that.
Kennyjoe
Post by Kennyjoe »
I seen another kit on lake hatchnaha some friends are building from St. Cloud. Really clean looking, don't get to see them much, my cousin rides with them all the time. They are all riding some badass steps hulls. Going to put one on my boat when I can afford it.
DD supercharged 0-480 13 ft. Lazer 3 blade ngh
tom-tom 863
What were their systems like?
