220 starter ??
CRL81
220 starter ??
Post by CRL81 »
I have a 220 gpu and what I heard people refer to as a floating starter assembly not sure but my starter went bad and I went to Napa to get one they matched mine with one they had so i was happy until I put it on and it didn't work my starter had 11 tooth bendix and the new one was 10 went back to Napa they have already sent my core off and they don't know what I need now cause they don't have a 11 tooth I'm in a big dilemma anyone know what starter I could use I have 168 tooth auto flywheel
Comanche-pup
220 starter ??
Post by Comanche-pup »
I did the same thing, I went to a local starter shop and ordered correct bendix for 3.50 I think, it was under 5$
Oleboy87
Re: 220 starter ??
Post by Oleboy87 »
Where are you located?
CRL81
Re: 220 starter ??
Post by CRL81 »
Citrus county
AV8R040
Re: 220 starter ??
Post by AV8R040 »
post a picture of your starter and we can try to figure out the proper part number you need.
Nugent/Palin 2016
Oleboy87
Re: 220 starter ??
Post by Oleboy87 »
The part number that is on the starter I had before I went to Air Tec is 1326G and it is USA Industries brand 11 tooth. Still have it if your interested.
CRL81
Re: 220 starter ??
Post by CRL81 »
i got it figured out i was able to get my old starter back and just switched out the bendix gear thanx for all the help
