Where to buy rubber bushings for motor mount
sseater
Post by sseater » Fri Apr 19, 2013 10:08 am
I have a narrow deck 360 and I'm missing one if the rubber bushings. Anyone know where I can get them?
Tony480
Re: Where to buy rubber bushings for motor mount
Post by Tony480 » Fri Apr 19, 2013 10:09 am
Wally Moore or Don George in Orlando.
Scrapman123
Post by Scrapman123 » Fri Apr 19, 2013 1:20 pm
Schmidt airboats!
If you ain't running aircraft you ain't got nothin.
air-roberts
Post by air-roberts » Fri Apr 19, 2013 3:28 pm
i cut my own but we used to get the 57 chevy motor mounts they hold up good and cheap
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
darrell
Post by darrell » Fri Apr 19, 2013 8:59 pm
if you have the small ear use 66 mustang trailing arm bushings work awsome and a perfect fit or wally moore has some excellent ones as well
if you argue with an idiot who is the real idiot
12x7 traditions hull Moore built av540 74" ww
