Continental carbs
Shippee123
Continental carbs
Postby Shippee123 » Sat Apr 20, 2013 6:06 pm
Does anyone know if there are any type of adapter manifolds to use a standard carb on an 0300a continental?
twister69z
Re: Continental carbs
Postby twister69z » Sun Apr 21, 2013 12:31 am
MA3 carburetor will fit perfectly,what do you want to install?
Twister69Z
Shippee123
Postby Shippee123 » Sun Apr 21, 2013 1:30 am
I have a ma3-spa, but needs accelerator pump. Was wondering about switching to a non aircraft style carb.
twister69z
Postby twister69z » Sun Apr 21, 2013 8:29 am
If you are having difficulty starting the engine , install a easy primer in your system and overhaul the existing carburetor. Or you can look for a 10-4895 or a 10-4895-1 carburetor. Is this just for ease of starting?
Twister69z
Shippee123
Postby Shippee123 » Sun Apr 21, 2013 5:01 pm
Haven't started the motor, carb needs an accelerator pump and packing for around it. Still in the building process on the boat and was looking for a way around pricey aircraft certified parts. Is there anywhere to get non certified aircraft parts,or an aftermarket version.
Thanks
Qwikdiesel
Postby Qwikdiesel » Mon Apr 22, 2013 10:25 am
Accy pump and packings are under $100 brand new. Probably one of the cheapest repairs you'll have if you own an Airboat. Cutting corners can make for long nights in the marsh.
twister69z
Postby twister69z » Mon Apr 22, 2013 11:00 am
Qwikdiesel wrote:Accy pump and packings are under $100 brand new. Probably one of the cheapest repairs you'll have if you own an Airboat. Cutting corners can make for long nights in the marsh.
X2
Users browsing this forum: No registered users and 6 guests
