Oil temp probe leak
sseater
Oil temp probe leak
Post by sseater » Sat Apr 20, 2013 7:44 pm
I'm having a leak where the line comes thru the fitting in the center. Here are some pics. The engine just got overhauled so I may be missing something. Here's what I have.
swampsquatch09
Re: Oil temp probe leak
Post by swampsquatch09 » Sat Apr 20, 2013 8:40 pm
I had to get some brass fittings from lowes, that probe needs to seat on a surface otherwise it will just fall into the housing I had the same problem, also the only thread I could find that would fit it being a fine thread was a tubeing type fitting then drill out the inside of the fitting so the probe can pass through and seat to be tightened. It's worked so far I'm sure there's a spacific part for it but that the 5$ way iv found. I'm sure someone will chime in on it
:texas:
DIXIENOURMOUS
Post by DIXIENOURMOUS » Sat Apr 20, 2013 9:17 pm
Go to discount auto and get adapters had to do it when I installed a temp gauge on my diesel ranger
2013 AGI-A alumitech IO-540
I like Women like 6.0 powerstrokes.............. always blowin
