special tools for 0290
- Southern Airboat Member
what are some ideas on getting to these hard to get bolts mainly the 11/16 or 3/4 nut pics or advice on tools would be awsome
- Site Supporter - IV
Re: special tools for 0290
What ones specifically are you having problems with?
Photos would help and PLEASE fill out your profile, this isn't the government we ARE here to help you.
Twister69z
Twister69z
He means the cylinder nuts probably. Theyuse specialwrenches.you can order them fromaircraft spruce.
x2 what Twister said about your location.
That is mostly for your benefit anyway.
Aircraft Tool Supply has the wrenches that I think you are referring to.
- Stewie
- Site Supporter - III
You can order aircraft cylinder wrenches look Online or on eBay I just purchased a whole set for 50.00! Also what's your location?
Confused because they are 9/16 and 3/4 ok what the others said..... cylinder wrenches.littlebigswole wrote:what are some ideas on getting to these hard to get bolts mainly the 11/16 or 3/4 nut pics or advice on tools would be awsome
Twister69z
All info is filed out and yes the tools are for the cylinder nuts 3/4 and9/16.
You can get them here. www.aircraft-tool.com
