Upstack 200 or o540
Jabroni
Upstack 200 or o540
Post by Jabroni » Wed Jun 12, 2013 3:08 pm
I have a 12 jb with a 160hp. Looking to upgrade don't wanna push that much anymore, what would be the motor to go to 200 up stack or 0540
Just got down in DX land, DOOFUS standing by reading the MAIL
sseater
Re: Upstack 200 or o540
Post by sseater » Wed Jun 12, 2013 3:12 pm
why does it have to be upstack 200? with your boat id get a 200 0-360. youll go anywhere the 540 boats will and burn less gas
Tony480
Post by Tony480 » Wed Jun 12, 2013 3:25 pm
No replacement for displacement.The 540 will hold its value better than a 4 banger. And set up right they arent bad on fuel.I can run from loughmans to lone cabbage and back on 15 gallons.
farmboy
Post by farmboy » Wed Jun 12, 2013 3:34 pm
[quote="Tony480"]No replacement for displacement.The 540 will hold its value better than a 4 banger. And set up right they arent bad on fuel.
I'm with Tony 100% on that. I would defiantly go with the 540... And JB's are free as hell anyway it shouldn't be bad at all on fuel. JMO!
Bruce
Post by Bruce » Wed Jun 12, 2013 3:48 pm
200 will hold its value just about as well as the 540 but initial cost between the 2 is about the same so u know where im at on this one 540 all the way fuel burn wont be much different because that 540 wont have to work very hard to push ur little rig
12 foot Mamba "The Underdog"
g1moore1
Post by g1moore1 » Wed Jun 12, 2013 4:49 pm
Jabroni wrote: don't wanna push that much anymore
Me either lol. That boat already goes anywhere, u just let that sticky green get to you. :lol:
Jeffords/520 on a 13' Gilileo/Phillips hull. Running a 72" WT narrow. (Needs bigger prop now)
http://WWW.USFTH.COM
P.Vento
Post by P.Vento » Fri Jun 14, 2013 6:47 pm
I'm impartial but I'd say upstack 540 , do both
DDSBC
Post by DDSBC » Fri Jun 14, 2013 6:57 pm
I'd say down stack exhaust, side stack cylinders and up stack carb O-360 to make sure you got all the angles covered lol. 360 will use less gas, less oil, less spark plugs, less wires, weigh less weight be less parts to rebuild and or maintain in the long run....... Never owned a 540 but my IO-520 is a gas hog and my buddies 180hp O-360 is the least fussy easiest to maintain long term engine I've personally seen.
Micah Smith
BCAHCC, KRVSA and lifetime NRA member
12x7 Diamondback w/ rivited on poly, double rear driver double front passenger, full cage, 285 hp IO-520 swingin a 74" Whirl Wind Whisper Tip.
rac1boat
Post by rac1boat » Fri Jun 14, 2013 8:27 pm
I've been airboating for 44 years now and have had Carmotor DD, Carmotor Belt drives, Carmotor Geardrives, and Aircraft. I currently own a IO-520D, IO-360 upstack, O-200A, IO-540K. The IO-360 is the only motor that has impressed me! JMO
Bruce
Post by Bruce » Fri Jun 14, 2013 8:49 pm
DDSBC wrote:I'd say down stack exhaust, side stack cylinders and up stack carb O-360 to make sure you got all the angles covered lol. 360 will use less gas, less oil, less spark plugs, less wires, weigh less weight be less parts to rebuild and or maintain in the long run....... Never owned a 540 but my IO-520 is a gas hog and my buddies 180hp O-360 is the least fussy easiest to maintain long term engine I've personally seen.
Ur problem is in the fuel system
todd glover
Post by todd glover » Fri Jun 14, 2013 9:59 pm
Now that's funny Bruce you coming 7/6/13
Bruce
Post by Bruce » Fri Jun 14, 2013 10:03 pm
todd glover wrote:Now that's funny Bruce you coming 7/6/13
i doubt it no boat and thats the heart of my busy season
todd glover
Post by todd glover » Fri Jun 14, 2013 10:07 pm
That blows but money is first playing is second don't blame j
Bruce
Post by Bruce » Fri Jun 14, 2013 10:13 pm
todd glover wrote:That blows but money is first playing is second don't blame j
oh well money makes playing more fun lol
Jabroni
Post by Jabroni » Sat Jun 15, 2013 6:10 pm
Yeah probably go 360 cause they say only thing I will have to change is rear mount
Dglover
Post by Dglover » Sun Jun 16, 2013 12:41 am
:old_glory: Don't waste your time had both. You will be super happy when you feel those two extra cylinders firing. Way more push you only live once Best airboat engine out there Lycoming 0540 Stick with a downstack lot less headaches with the exhaust system.
P.Vento
Post by P.Vento » Sun Jun 16, 2013 8:48 am
Your comparing lycoming and continental, no comparison there, continentals suck, lol
Post by Deano » Sun Jun 16, 2013 8:57 am
They got no corner on that market . . . anything that is naturally aspirated sucks. :mrgreen:
05DirtyMax
Post by 05DirtyMax » Thu Jun 20, 2013 7:39 pm
Come on now what's wrong with a Continental?
13 Foot Laser with a wore out 520
fl cracker
Post by fl cracker » Thu Jun 20, 2013 8:00 pm
Take it from somebody who came from a 200 +HP 4 banger. I didn't think the 540 would be big difference but definitely was. I don't know if I could do a 4 banger again.
" I have two guns...
One for each of you "
2017 Al David / stroked LS
SwampNinja
Upstack 200 or o540
Post by SwampNinja » Thu Jun 20, 2013 9:36 pm
I have a 200. Hopefully one day ill upgrade to an 0540.
"It is what it is."
