Boat cought on fire again
deerhuntindev
Post by deerhuntindev »
Have a franklin 165. The boat woundnt start up then finally it fired up and then backfired when i look down my carb was a big ball of fire. So i had my carb rebuilt an just put it on today. The motor just kept turning over with out fireing up, so i got mad and walked away for a hour then tried agin. After 5 mins she fired up an backfired immediately. An again my rebuilt carb was on fire. This is the 2nd time its done this. Anybody know what is out of wack?
boatair
Site Supporter - VII
Re: Boat cought on fire again
Post by boatair »
Have you checked your mags?
boatair
Post by boatair »
Plugs?
deerhuntindev
Plugs are all new and im gettin fire from all of them. I dont want to pull my mags off because im not good on aircarft. This is my first aircraft boat so im still learning them
Cutler
Post by Cutler »
My guess is you have a timing issue not a carb issue
Post by Deano »
I'd say that's a pretty good guess. :thumbleft:
IF the plugs fire with the intake valve in any postion other than fully
closed, the carb will have very little choice about what happens next.
kajunoutlaw
Post by kajunoutlaw »
Try to search for a "mag" manual on line. It should tell you how to set your timing. That is where I would start anyway.
Great minds discuss ideas, Average minds discuss events, small minds discuss people.
Adm. Hyman G. Rickover
Wild Bill
Post by Wild Bill »
While your playing with your mags. If the carb starts on fire again turn the mags off and keep cranking, fire should go out.
Could also be rroken valve spring or dropped intake valve seat
boobidges
Post by boobidges »
Classic aire in Georgia. Mans nameis Bruce Kown. I boughtmy manual from him. Great guy , very knowledgeable. Set timing at 25degrees before tdc
boobidges
Post by boobidges »
HAMMERHEAD
Post by HAMMERHEAD »
yes check compression on eachcylinder sounds like a spring or seat and plug is firing with intake valve open. easy to check and eliminate for trouble shooting.
FLCGC4H2O
Post by FLCGC4H2O »
Valve(s) are not seating correctly allowing pressurized ignited fuel to get pushed back through the inlet port to the carb.
check valves seats, and all mating surfaces.
Just a thought.
14' Alumitech 383 SBC 2.68 Rotator 3 blade 80" Sens. R
Polished sst rigging 3/8 poly goes where you want it to.
Post by John Fenner »
Need to check your valve lash.
