0300a been sitting
Shippee123
0300a been sitting
Post by Shippee123 » Mon Jul 15, 2013 12:08 am
I am trying to find out if there is a way to prime the oil system on a 0300a. It has been sitting and I didn't want to try to refire it dry and mess up any bearings. Thanks for any info.
twister69z
Re: 0300a been sitting
Post by twister69z » Mon Jul 15, 2013 7:31 am
Prime through the oil pressure fitting with a pump oil can. At least 1/2quart.
Twister69z
Post by John Fenner » Mon Jul 15, 2013 8:40 am
Then pull top plugs and spin it over till pressure builds, fire it up.
Shippee123
Post by Shippee123 » Mon Jul 15, 2013 1:24 pm
Thanks for the info, hope to have it running this week
Post by John Fenner » Mon Jul 15, 2013 1:35 pm
If the mags don't fire, take out the points and polish the contacts with a fine wire wheel.
Shippee123
Post by Shippee123 » Mon Jul 15, 2013 10:35 pm
I have one mag firing and one not, I have filed the contacts with a point file but still no luck with it.
