carbbed 540 popping through the exhaust
alumitech520
Post by alumitech520 » Tue Jul 16, 2013 4:38 pm
motor ran great at first , the started popping through the exhaust from the right bank ( pilots position) then occasionally from the left side. could this be from running pump gas . was told when I got the boat it ran good on pump gas with boost and marvel myst oil. sometimes it would pop more than others. tach isn't working so I cant give an rpm range. it seems to pop from mid range to high range rpms. or could it be from restricted fuel system causing a lean condition? does have a man pump and elect pump it that helps any. need all the advise I can get , I don't want to cause any damage to the engine . thanks guys for all info given.
Dreadneck
Re: carbbed 540 popping through the exhaust
Post by Dreadneck » Tue Jul 16, 2013 4:43 pm
check the plugs
twister69z
Post by twister69z » Tue Jul 16, 2013 4:43 pm
Compression test first, then the tale will be told.....
Twister69z
schmidtav2
Site Supporter - VII
Post by schmidtav2 » Tue Jul 16, 2013 5:41 pm
Also look for any leaks at the intake pipes (gasket and hose) and at the exhaust gasket area.
cowtown
Post by cowtown » Tue Jul 16, 2013 5:43 pm
running lean !!!
http://usfth.tripod.com
And Proud Of It !!!
keebo
Post by keebo » Tue Jul 16, 2013 6:29 pm
as said before leakdown test first, all good answers but could be a mag too. Had it happen on SV carb 540
:old_glory: :florida: :GA:
alumitech520
Post by alumitech520 » Tue Jul 16, 2013 8:21 pm
I don't have the proper equip for leakdown test. but comp is as follows cyl 1 170 psi with a med brown plug , cyl 3 170 psi with carbon build up blk plug, cyl 5 170 psi with carbon build up blk plug, cyl 2 175 psi with med brown plug, cyl 4 175 psi with carbon build up blk plug, cyl 6 170 psi with carbon build up blk plug. all top plugs. im not sure how accurate the guage is , I borrowed it from someone else. while doing a little looking around , I checked to see if the throttle was opening all the way I noticed the accel shaft has a fair amount of play in it. tag on the carb says ma4-5 model number 10-3859-1. thanks again for info and advise given .
victorg
Post by victorg » Tue Jul 16, 2013 8:47 pm
I have a leak down tester you can borrow!
twister69z
Post by twister69z » Tue Jul 16, 2013 8:54 pm
Isn't Southern Airboat great! People loaning tools for fellow airboaters. Forgot to ask what kind of plugs? Automotive or aircraft? Try a tank of avgas also drain the carburetor bowl check for water.
Twister69z
alumitech520
Post by alumitech520 » Tue Jul 16, 2013 9:06 pm
autolite 386 , twister does the comp sound right to you? thank you for your help.. vic , I didn't know you had 1 , I would have gotten it the other night. thanks buddy.
loudmouse
Post by loudmouse » Tue Jul 16, 2013 9:24 pm
I would check the fuel filter, check mag, change plugs, refire and if the pop is still there the carb might have water or trash in it.
Built and Tuned by Me
breastquest
Post by breastquest » Tue Jul 16, 2013 10:08 pm
Run it till it pukes the part out that's causing it to pop!!
twister69z
Post by twister69z » Tue Jul 16, 2013 10:43 pm
At least they are close together, a differential test is more conclusive but that is coming..
Twister69z
