Prop spinning backwards
CypressHunter
Post by CypressHunter »
What causes that on shut down?
CJB0470
Re: Prop spinning backwards
Post by CJB0470 »
I have a stock 220 with a 500 Holley, single mag. If I run pump gas it raises the head temp and if I do not let it idle to cool it will diesel like you are talking about. Av gas solves the problem for me, 100ll it's the lead that keeps the head temp down. Regardless of what I'm running in the tank I always let it idle for a while before I shut it off.
Chris. :florida:
"Always do right. This will gratify some people, and astonish the rest"
-Mark Twain
southbound125
Post by southbound125 »
never seen them run backwards but if you run a hot plug or have a lot of carbon built up in the heads the fuel will ignite because carbon and or plugs are red hot and will give a ignition source. in my day we called that dieseling. we had all kinds of tricks to get carbon out like pouring water or trans fluid down the carb while reaving your engine. it never seemed to work though but we had a good time!
13.6 GTO / motivation by 383 small block chevy / OX BOX 2.68 to 1 / R blade prop !
swampsquatch09
Post by swampsquatch09 »
Mine does it if i shut down hot, just idol around a bit before you shut it off thats how I keep mine from spinning backwards at shutdown, i run pump gas 93 havnt ran enough avgas to notice anything
:texas:
Bruce
Post by Bruce »
if its a gpu like your signature suggests and you have an electric fuel pump just shut it off and let it run out of fuel gives it time to cool down and wont diesel now if you have a manual pump let it idle a couple minutes which you should always do anyways then bring it up to 12-1400 rpm cut the mag and push the throttle to the floor may not be the right way but it wont run backwards like that
12 foot Mamba "The Underdog"
dusty burch
Post by dusty burch »
If u put av gas in it it will shut off properly
TheElevatorGuy
Post by TheElevatorGuy »
I don't know why or how but my 220 luckily never does that......I have seen others do it.......and I have always ran 93 in it because the previous owner did too....... :scratch:
I try to let it idle and cool off before shutdown but not always and even in an immediate shutdown it does not do it!!!
Stewie
Post by Stewie »
I always let it idle for a min then just pull my lean rich cable All the way up to lean and it shuts off easily. :old_glory: :rebel: :florida: I have also seen the 220 zenith carbs with the fuel shutoff solenoids does the same thing no diseling.
SkinnerBack
Post by SkinnerBack »
Or shut it off by pulling the lean out all the way up if you have one.......
swampsquatch09
hogdogs2009 wrote:I always let it idle for a min then just pull my lean rich cable All the way up to lean and it shuts off easily. :old_glory: :rebel: :florida: I have also seen the 220 zenith carbs with the fuel shutoff solenoids does the same thing no diseling.
How do you have your lean rich cable set up? is it similar to the way a throttle is set up with a cable or rod?
:texas:
mcm4
Site Supporter - VII
Post by mcm4 »
I had the same problem with my bbc....
I solved it by putting an idle solonoid on the carb, when I flip the switch the idle drops down to about 300 and as it is doing that I can turn off the ignition with no dieseling....
pretty simple and cheap setup
cummins diesel power
Post by cummins diesel power »
mine diesels when I stop sometimes, but if I just let it idle for a little bit
before I shut it off it wont diesel
15x7 1974 airgator,500 cadillac dd,74" q series sensenich prop, 1/2" uhmw poly.
18x8 2001 panther, 502 chevy, 2 to 1 century,3 blade 78" stump puller, 1/2" poly
In the Glades
Post by In the Glades »
Need to let it cool off or lean it out til it turns off.
BCAHCC Member
Stewie
Post by Stewie »
I used a small $30.00 pto cable and just made a bracket to hold the cable in the position to work my lean and rich very easy to do push and pull! :old_glory: :rebel: :florida:
Post by John Fenner »
Idle setting may be too high and too rich, adjust it down to about 400 RPM then carefully with a stubby screwdriver turn in the idle mixture screw (top rear center of carb) till it begins to stumble and cut off, then back it out till it idles smoothest. It might have 10:1 pistons and too hot of a plug, a bit more information like this could steer us to a better cause.
