enough power for a deckover?
jopete
Post by jopete » Fri Jun 27, 2014 1:11 pm
Well, with the price of a tight lycoming being what it is, i think i may just find me a good gpu for my next project.
will a 220 push a 12' don davis deckover ok? i'm talkin stock gpu with a 500 holley carb.
i may have found a engine stand this week.
my old stock gpu is pretty tired but will still climb thru the cypress knees when i need to get a deer or hog out the swamp. the deckover will be my first one and looks too danged pretty to put in the woods. nobody around south la runs a deckover, but i have the fever.
i hadn't got the hull yet, so no pics untill i am sure i can work the deal out with the current owner.
Bruce
Re: enough power for a deckover?
Post by Bruce » Fri Jun 27, 2014 1:45 pm
jopete wrote:Well, with the price of a tight lycoming being what it is, i think i may just find me a good gpu for my next project.
Will push it no prob
12 foot Mamba "The Underdog"
scottyroll
Post by scottyroll » Fri Jun 27, 2014 1:47 pm
The GPU is a little bit more chunky and underpowered compared to its AV brother but will push a well built deckover like you have mentioned just fine.
:Scotty-Roll:
FLAwless
broncobill
Post by broncobill » Fri Jun 27, 2014 1:50 pm
The GPU is lighter than a lycoming 0540 by about 80 LBS.
yobee
Post by yobee » Fri Jun 27, 2014 2:08 pm
Stossel used to send tons of boats to Louisiana!
scottyroll
Post by scottyroll » Fri Jun 27, 2014 2:10 pm
broncobill wrote:The GPU is lighter than a lycoming 0540 by about 80 LBS.
I didn't know the GPU had a displacement of 540ci...my bad :scratch:
surely the GPU is not lighter than a o470...
:Scotty-Roll:
FLAwless
Bruce
Post by Bruce » Fri Jun 27, 2014 2:26 pm
surely it's not lighter than a o470...
Why wouldnt it be case and cylinders are quite a bit lighter
yobee
Post by yobee » Fri Jun 27, 2014 5:27 pm
Broncobill ain't got your normal gpu either lol.
P.Vento
Post by P.Vento » Fri Jun 27, 2014 5:49 pm
I know the cranks are liter in a gpu and that's not a good thing,lol
Post by :) » Fri Jun 27, 2014 9:11 pm
:banghead:
Gary S
Post by Gary S » Sat Jun 28, 2014 6:45 am
Don Davis has a 520 conversion ready to go.
Post by John Fenner » Sat Jun 28, 2014 9:00 am
It will push it with no problem.
jopete
Post by jopete » Sat Jun 28, 2014 1:34 pm
thanks for the replies. i am getting pumped up about putting it all together!!!
jopete
Post by jopete » Sun Jun 29, 2014 3:56 am
i read that somewhere on here!!!!! lol
jopete
Post by jopete » Fri Aug 22, 2014 12:07 am
UPDATE.....
we shook hands on the 12' Don Davis deckover today. it will take me a couple of months to get the $$$ together, but it is all worked out.
I need one like a hole in the head, but dang-it i ain't gonna pass on the chance to see what allthe fuss is about. lol
my plan is to modify the engine stand from lycoming to gpu and drop in my motor from my current boat.
i didn't have the $$ to get the 300 lycoming that is on it now.
i'll post some pics in a few weeks.
scottyroll
Post by scottyroll » Fri Aug 22, 2014 9:35 am
:banghead:
I weighed a carbureted parallel valve O540 and a fuel injected angle valve O540 Lycoming, I also weighed a 520 Continental and a GPU470. The parallel valve weighed 448LBS the angle valve weighed 473LBS and the 520 ironically weighed 520LBS and get this one the 470GPU weighed a whopping 570LBS. All motors had lightweight starters, alternators, flywheels and headers the 220GPU was the only one with an oil cooler. I used our lab scale that is certified and calibrated quarterly and then double checked it against our shipping scale. Both read within 3LBs. I also have a Lycoming operators manual that shows 16 different versions of O540’s that all weigh over 400LBS. Funny you mentioned this because I presently have a bet with a buddy that an O540 weighs over four hundred pounds. He swears they don’t he has several Internet sources claiming so but I go by what I see with my own two eyes on a scale that I know is calibrated. I have also weighed some Lycoming 160’s and 180’s.
That was posted by waterthunder a while back. It doesn't weigh the O-470 and the paragraph has some weird characters but overall Kind of what I was thinking...
:Scotty-Roll:
FLAwless
Scarecrow
Post by Scarecrow » Fri Aug 22, 2014 12:31 pm
How in the heck are you gonna get all the stuff you carry in a decked over boat? :lol: :rebel:
jopete
Post by jopete » Fri Aug 22, 2014 1:20 pm
i'm gonna quit being a boy scout and just carry a icechest, a 2 gal gas can, and 4 qts of aeroshell like they do in Fla. !!! lol
i figure i can just throw the deer/ducks o the front deck and wash the blood off later!!!!
riverrat1
Post by riverrat1 » Fri Aug 22, 2014 2:44 pm
I had a gpu on a 15' river master and it would run ground fine green grass it was rough, just get A good one. You can always put 470 jugs on it. The ground power is a good motor.
FLA BOY
Post by FLA BOY » Fri Aug 22, 2014 10:02 pm
Listen to Scotty Roll. He seems to be an expert.
GSO480/12' Hammant
GPU/12' Richochet
scottyroll
Post by scottyroll » Sat Aug 23, 2014 8:41 am
Fla boy, I'm just sharing information that I have read on the countless pages of this forum.citing another person in this instance.
:Scotty-Roll:
FLAwless
glades cat
Post by glades cat » Sat Aug 23, 2014 2:20 pm
Congrats on your Don Davis full deck. If the4 GPU is in good shape it will be a good power plant.
Les bon temps roulez. I guarauntee.
Duckhunter_012003
Post by Duckhunter_012003 » Sat Aug 23, 2014 2:22 pm
We ran deckovers in the maurepas swamp for years
Don't go saying people in louisiana don't run deckovers, we ran one for years in the maurepas swamp
jopete
Post by jopete » Sun Aug 24, 2014 2:06 am
well then, i stand corrected!!!!!
i know i spend more time outdoors than most, and they are few and far between on my end of the state. i am looking forward to changing that. lol
FLA BOY
Post by FLA BOY » Tue Nov 18, 2014 2:45 pm
Farmboy, lol.
GSO480/12' Hammant
GPU/12' Richochet
