Who are the best engine builders?
jeepinocala1111
Post by jeepinocala1111 » Wed Jul 23, 2014 12:36 pm
I am considering just buying the parts and doing it myself but first want to investigate who to go to and have zero worries? 220 gpu. I know nobody wants
to post prices so simply pm me a quote all
I want done is 5 rebuilt cylinders .015 over
rings, rod bearings and the gasket sets installed.
My engine needs to be freshened up smokes a bit
too much for me.I replaced one cylinder it had real low
compression from a cracked head the rest seem to run
good with good compression. I am sure most if not
all of them could be rebuilt I dont want to wait.
Pistons in it are dome top aircraft that have the extra
skirt ring .015 over with a flat
milled on the top to run pump gas. The rod bearings
are .020 over. You have to have this in stock I
dont want to wait a month. If you are too busy and
have this stuff in stock give me a price for the parts.
Re: Who are the best engine builders?
Post by One Eyed Gator » Wed Jul 23, 2014 2:45 pm
If your in Ocala
Lacey Everet
Jim Lauderdale But I think he sold a lot his stuff of to a guy in webster just can't remember his name Heard he builds a great motor
Bruce at circle S (Parts)
JT540 on SA Think his name is justin
Walley Moore
JC Stanley
Gary Armstrong
Schimidt Aviation
I am sure there are a few more
PM Sent
Last edited by One Eyed Gator on Wed Jul 23, 2014 2:57 pm, edited 1 time in total.
Comanche-pup
Post by Comanche-pup » Wed Jul 23, 2014 2:54 pm
Bruce at circle s will also build and is very good but the racers come first
Post by One Eyed Gator » Wed Jul 23, 2014 3:00 pm
Yes he can build and build them bad to the bone, but that is kind of why I said Parts, he has building full of them.
Crazy Frog
Post by Crazy Frog » Wed Jul 23, 2014 3:11 pm
If you are running the 6th cylinder as a standard bore...make sure they gram weigh the pistons to match!!
jeepinocala1111
Post by jeepinocala1111 » Wed Jul 23, 2014 5:40 pm
I really want to know who to stay away from.
rocketman
Post by rocketman » Wed Jul 23, 2014 6:59 pm
The fella north of Webster is Russell Knapp and he builds a fine engine. He built me a PE-90 / 520 conversion and it is a thing of beauty. Very particular about his work and stands behind his product. All others mentioned above have good reputations I'm just more familiar with Russell's work. I will post a pic when I figure out how.
Comanche-pup
Post by Comanche-pup » Wed Jul 23, 2014 8:53 pm
Everyone we are not mentioning is who to stay away from
P.Vento
Post by P.Vento » Thu Jul 24, 2014 6:32 am
All I can say is get more opinions, sometimes this sites forum can hurt more than it helps
Whitebear
Post by Whitebear » Thu Jul 24, 2014 6:50 am
Probably best to PM any negative comments. :lol:
dynaairglide
Post by dynaairglide » Thu Jul 24, 2014 7:53 am
One name not mentioned was SpeedWheelie, a.k.a. Tom Jeffords. I took him a G.P.U. engine, with great oil pressure, and he turned it into a sweet running, ground burning machine. He got me some real nice 0470 aircraft jugs, installed another mag, and replaced my old 4-barrel with a new Holley 500 2-barrel. It used 1/2 qt. of break-in oil, and is yet to use another drop. I ran the break-in oil for 13 hrs., and have 20 hrs. on the regular aeroshell. I have read on this site, where a huge amount of oil is used during some break-ins, and then it continues to use oil every trip. I have not experienced anything like that. Even if you did not want to go for a total conversion, he would get my vote to freshen your unit up. I could not be happier with my engine. He's located in the Auburndale/Winter Haven area.
Be American... Buy American!
plumcrazy
Post by plumcrazy » Thu Jul 24, 2014 8:31 am
tom Jeffords is my choice..... he only uses top shelf parts and the guy cant tell a lie .... 500 hours on my gpu conversion don't burn a drop.... 863 956 3030 :thumbleft:
Monkeydust
Post by Monkeydust » Thu Jul 24, 2014 8:41 am
Tom did my pe90 conv and stands by his work
Outlawaircraftengines
Post by Outlawaircraftengines » Thu Jul 24, 2014 11:27 am
Damn....Me and Jurnigan got left out. I feel violated. Lol
Gary Barber
Outlaw Aircraft Engines
www.outlawaircraftengines.com
863-698-0383
mojoe
Post by mojoe » Thu Jul 24, 2014 11:53 am
Wally Moore .
Mark 7:9
plumcrazy
Post by plumcrazy » Thu Jul 24, 2014 1:35 pm
Outlawaircraftengines wrote:Damn....Me and Jurnigan got left out. I feel violated. Lol
waaaaaaaa!!!!! :fishing :D
Post by Outlawaircraftengines » Thu Jul 24, 2014 2:17 pm
Ok plum I'll do it. I'll put a turbocharger on your motor so you can have 500up and outrun Terry farkas. Lol
Gary Barber
863-698-0383
dusty burch
Post by dusty burch » Fri Jul 25, 2014 12:46 am
Shane buie in melrose I buy my parts from him pretty regular for different boats 386 972-2586
jeepinocala1111
Post by jeepinocala1111 » Fri Jul 25, 2014 6:48 am
I am doing a leakdown test this weekend. Yesterday after work I ran it again up to maybe 140deg and it only had some real small puffs of white smoke only when you hit the throttle. I am sure it's not a fresh motor but could the new cylinder until it breaks in create enough pressure in the case to create this issue? I plan to rebuild the 5 cylinders that have not been no matter what I find just so i know what I have.
Big Casino
Post by Big Casino » Fri Jul 25, 2014 8:13 am
JeepinOcala ... I'd have to recommend Russell Knapp also, namely because he apprenticed under Jim Lauderdale. I've got the last gitsu Jim built before he retired. Not the cheapest, but i can attest to the quality and attention to detail ... that's just my $0.02
"...This above all: to thine own self be true..."
Post by Outlawaircraftengines » Fri Jul 25, 2014 9:29 am
Do a leakdown and if they are over 65/80 and not burning any oil, leave them alone. Blowby exists because the combustion gas is escaping from the cylinder into the case. Excess can either mean the rings have not seated or the other side is the cylinders/rings are worn. A leakdown will tell you what you need to know.
Last edited by Outlawaircraftengines on Fri Jul 25, 2014 12:51 pm, edited 1 time in total.
Gary Barber
863-698-0383
jeepinocala1111
Post by jeepinocala1111 » Sat Jul 26, 2014 5:52 pm
Well after all of the pm's and research I have done I have decided to rebuild the top end myself. Now I have to find all of the parts :violent1:
woodwagon
Post by woodwagon » Sat Jul 26, 2014 9:25 pm
Check with lacy Everett. He knows his continentals and may have all the parts u need. I just had lacy rebuild my motor and couldn't be happier. You'll have a hard time finding a man with more knowledge about aircraft motors.
P.s. he will also give u a straight up honest answer to any question u have. So if u have thin skin call someone else.
When in doubt, throttle out!
jeepinocala1111
Post by jeepinocala1111 » Sat Jul 26, 2014 10:11 pm
Yes I do know Lacey very up front guy in a good way. I am just going to hunt the parts down Lacey does not carry these parts on hand. I have called him and made the mistake of telling him it is a gpu :slap:
Mudlife81
Post by Mudlife81 » Sun Jul 27, 2014 10:11 am
Steve Warrior engines
