Airflow Performance Injection
SkinnerBack
Post by SkinnerBack »
Anyone know anything about this injection or how it works & is it worth money!!!
KR23
Re: Airflow Performance Injection
Post by KR23 »
Yes, it is great. I have never had an issue with mine, fires right up every time, cold, hot, snowing it don't matter. Well worth the money. You will be happy as hell and there customer support is awesome, great people to deal with. My brother is putting it on his new motor, out with the carb and in with the injection. It is pricy that's why a lot of people avoid it, but you are getting brand new stuff. Contact Al at performance airboats or warrior engines, both numbers are in my signature block.
SkinnerBack
10 4 I saw they are pricey but I'd rather have something that works correctly than dealing with my temperamental injection........ Do you take your boat to them & they install it or do they ship it to you & you install it?
P.Vento
Post by P.Vento »
What's pricy? I want to try it
Dirtman
Post by Dirtman »
looks like between 2500 and 3100 depending on engine horsepower rating and servo size
SkinnerBack
I want to try it too........ i have the regular bendix injection & cant seem to get it right, think im gonna call them & talk to them about it while i got it on the brain!!
KR23
Post by KR23 »
Contact Al at performance airboats and tell him dan sent you, he's got it down and can walk you through the process. He knows what you need and don't need we also found places that carry some of the same parts for less money. Airflow is second to none when it comes to injection.
KR23
Post by KR23 »
They send it to you and you install, if your in the central fl area I would contact Al and have him order and install it for you, so he can show you something's.
SkinnerBack
I have a spacer jug 540 11to1 motor with bendix injection, I was rich like would look like a diesel when you mashed on it, now I'm running lean discovered this Saturday, so lean it's runnin my motor hott & breaking down around 220 225......
Dglover
Post by Dglover »
:old_glory: There is nothing wrong with your Bendix system. Call airflow directly great guy's send them your servo,injectors and flow divider. They will rebuild it and set it up perfectly on their flow bench dialed right in for your combination. No need to go spend 3200$ on their's not worth the little gain if any over what you have and that cost me $700.00 to redo. I did on my angle valve 0540 ran absolutely perfect. fired right up all the time. Just wondering if your running a rotory romec style pump or are you running a high pressure diaphram plunger pump ?
SkinnerBack
High pressure plunger pump...... I called them friday but the technicians were out of the office..... I will call them back monday.
contagious
Post by contagious »
i have ran airflow on my drag boat and installing on a ride boat now. Very good system can't go wrong. Theres a couple little tricks to getting them right. Feel free to shoot me some questions we'll get u pointed in the right direction.
SkinnerBack
Just talked to the guys @ airflow..... Don gave me things to check to see what's goin on...... So I have a few things to do this week after work......
woods and water
Post by woods and water »
All injection is temperamental you have to get system clean then go from there
SkinnerBack
Yeah I'm trying too
mwood7800
Post by mwood7800 »
SkinnerBack wrote:I have a spacer jug 540 11to1 motor with bendix injection, I was rich like would look like a diesel when you mashed on it, now I'm running lean discovered this Saturday, so lean it's runnin my motor hott & breaking down around 220 225......
I have the same motor, I sold the bendix and went to a carb, ran better, starts better, I would either get Continental injection or a carb. I went to injection on my airplane and it made little if any difference.
