Help!!!! Starter Issues
toad36racing
Post by toad36racing » Sun Oct 26, 2014 12:45 am
hey guys, help with, finding a starter and a flywheel to fit a Continental GPU. What will fit/work on them? The one I have just "grinds" on the fly wheel while spinning it over. Teeth are a bit worn on the flywheel. Also, seems like the starter doesn't have enough torque to turn the newly redone top end engine. Spins about 4 times and gets slow.
hmgm123
Re: Help!!!! Starter Issues
Post by hmgm123 » Sun Oct 26, 2014 9:02 am
Try leaving your mags off while starting then turning them on once you got it spinning good. Check your brackets make sure their not flexing.
REAL 7.3
Post by REAL 7.3 » Sun Oct 26, 2014 12:48 pm
Call speed wheelie. He sells the Norman Clay kits 863-956-3030
11' Gillieo PE90
toad36racing
Post by toad36racing » Sun Oct 26, 2014 3:44 pm
hmgm123 wrote:Try leaving your mags off while starting then turning them on once you got it spinning good. Check your brackets make sure their not flexing.
Just one mag by the way. Yes the bracket does flex a bit.
toad36racing
Post by toad36racing » Wed Nov 05, 2014 11:31 pm
The flywheel i have is a 160 tooth chevy. Having trouble finding a match.
Thunder200
Post by Thunder200 » Thu Nov 06, 2014 2:31 am
The Norman Clay kit is the cats meow. Cost you initially but well worth never having these headaches in the future.
Prototype
Post by Prototype » Thu Nov 06, 2014 9:45 pm
Thunder200 wrote:The Norman Clay kit is the cats meow. Cost you initially but well worth never having these headaches in the future.
AH? Not so fast on that! Great kit, Not so great starters with the holley carb conversion on top!
