PROPER ENGINE MOUNTING
Lwells
Post by Lwells » Fri Dec 19, 2014 11:56 am
I am a newby airboat owner and need some help. This is all new to me as far as the boat rigging and engine hookup. I have a 2000 Panther rigged for a 320 lycoming. I bought a 320 mounted on a stand but my question is: When I put the engine in my boat I have two mounts, upper and lower and then a lower mount on other end that is a single. I have mounts and bolts for the lower mounting due to engine mounted on stand but don't have uppers. I would think that engine should be mounted with the upper and lower mounts when mounted on the boat. If so then I need to buy the upper mounts and bolts. Am I correct on this or do they just use the lower mounts. Thanks for any help .
terrible ted
Re: PROPER ENGINE MOUNTING
Post by terrible ted » Fri Dec 19, 2014 12:38 pm
If the provision there i would use it.
Whitebear
Post by Whitebear » Fri Dec 19, 2014 1:03 pm
My O360 200 used all four front mounts and a single rear mount. Smart money says use all the mountings ya can.
Lwells
Post by Lwells » Fri Dec 19, 2014 8:49 pm
Thanks, I figured I should use them all but thought I would ask. Where is the best, cheapest and or closest place or person to get some lord mounts and bolts in the Okeechobee area?
Lwells
Where can or from whom in the Okeechobee area can I get some engine mounts with bolts?
getchasumairboats
Post by getchasumairboats » Fri Dec 19, 2014 9:35 pm
Triple W airboat in okeechobee
http://WWW.USFTH.COM where the weak are killed and eaten !!!!!
Lwells
Post by Lwells » Sat Dec 20, 2014 8:33 pm
They said they didn't have a full set but I also need stainless rudder rods so maybe they will have those
