What Transfer pumps used on av100ll
terrible ted
Post by terrible ted » Sat Dec 20, 2014 11:07 am
so what pumps are any of you using weather manual or powered.
I need to fix or replace my transfer pump and looking for information on what best.
getchasumairboats
Re: What Transfer pumps used on av100ll
Post by getchasumairboats » Sat Dec 20, 2014 7:21 pm
I used a fill rite 15 gpm and never had a problem.
http://WWW.USFTH.COM where the weak are killed and eaten !!!!!
terrible ted
Post by terrible ted » Sat Dec 20, 2014 8:11 pm
Any body fix them?
Shippee123
Post by Shippee123 » Sat Dec 20, 2014 10:17 pm
If it's a 12 volt here is the rebuild kit. Easy to do.
http://www.northerntool.com/shop/tools/ ... oCKznw_wcB
terrible ted
Post by terrible ted » Sun Dec 21, 2014 9:01 am
Its an electrical issue. Maybe a starter rebuilder shop. It was not the switch I had it open maybe I take it completely apart and see what I can do. My manual pump is leaking too.
whslogging
Post by whslogging » Mon Dec 22, 2014 1:07 pm
i run alot of the fill-rite 15 and 20 gpm pumps... the switch or circuit breaker is the problem 90% of the time or when it will not come on someone beats on it with a hammer !!! all that does is brake the magnets and then it's only good for parts. it is very rare for these pumps to wear out .
whslogging
Post by whslogging » Mon Dec 22, 2014 1:13 pm
take the 4 bolts off the pump cover and look at the pump , i have see one of the vanes break and lodge , if that happens just remove the broke one ,,, put cover back on ,,, and keep pumping..
terrible ted
Post by terrible ted » Mon Dec 22, 2014 5:39 pm
what i found is if i wiggle the wire that i think is going to the armature it kicks on and off. yes I by passed the switch while i was bench checking it.
Post by John Fenner » Mon Dec 22, 2014 11:52 pm
Facet pumps version that is bendix old cylindrical design with 1/4" npt ports is best.
terrible ted
Post by terrible ted » Tue Dec 23, 2014 9:10 pm
I talking for a gas pump style transfer tank.
whslogging
Post by whslogging » Wed Dec 24, 2014 2:56 pm
what brand pump do you have ?
terrible ted
Post by terrible ted » Wed Dec 24, 2014 10:01 pm
I have a fill rite that's not functioning.
whslogging
Post by whslogging » Wed Dec 31, 2014 12:14 pm
sorry i havent gotten back sooner ,, holidays and all !!!
do 2 things ,,, on the pump end there's a cover with 4 bolts . take it off and look at it there are 5 vanes , spin pump with you fingers or something if it spins free its not the pump ... next take the switch cover off and unhook switch and circuit breaker,,
you should only have 2 wires coming from motor , a white and yellow . hook it up to 12 volts ,, if it runs there is nothing wrong with motor ..just replace switch and delete circuit breaker,,, i alway up grade to a 30-35 amp switch..
terrible ted
Post by terrible ted » Wed Dec 31, 2014 6:12 pm
whslogging wrote:sorry i havent gotten back sooner ,, holidays and all !!!
yea I wiggle one of those 2 wires past the switch and it will run intermittently.
whslogging
Post by whslogging » Wed Dec 31, 2014 9:30 pm
i have gone deeper into these motors,, brushes and springs do wear out but it takes alot of hours of run time... take it apart and see if you can see what's up ,,,you aint gonna hurt it
terrible ted
Post by terrible ted » Thu Jan 01, 2015 8:12 am
that's what I am going to do, nothing to lose.
whslogging
Post by whslogging » Thu Jan 01, 2015 9:11 am
let me know what you find ... i got dozens of parts pumps and might have the part you need.
terrible ted
Post by terrible ted » Thu Jan 01, 2015 3:40 pm
I have no idea- all I can gather is bad connections. I cleaned the pump and the connections, not sure if I rewired the switch the same way but everything is working now.
