how much hp out of a 0435 with angle valve cylinders
BLOWME SIDEWAYS
Post by BLOWME SIDEWAYS » Mon Jan 26, 2015 9:40 am
Im buy an angle valve 0435 on a 13 ft hull tight motor what hp should I expect and it has a 72 5 blade warp what rpms should I run
woods and water
Re: how much hp out of a 0435 with angle valve cylinders
Post by woods and water » Mon Jan 26, 2015 10:03 am
I think 240hp
keebo
Post by keebo » Mon Jan 26, 2015 11:31 am
More like 212hp @ 3000rpms, what the specs say anyway, my old wore out 240hp 0470 spun alot more pitch in the same prop as a buddys AV0435 with fresh rebuild.
:old_glory: :florida: :GA:
Packman
Post by Packman » Mon Jan 26, 2015 5:29 pm
keebo wrote:More like 212hp @ 3000rpms, what the specs say anyway, my old wore out 240hp 0470 spun alot more pitch in the same prop as a buddys AV0435 with fresh rebuild.
x2
Swamp nugget, Your four banger bud
SJRAA VP
dusty burch
Post by dusty burch » Tue Jan 27, 2015 7:45 pm
Im pretty sure that a 435 is 190 hp
pirate
Post by pirate » Wed Jan 28, 2015 9:40 am
According to Lycoming:
O-435-A 190hp @2550 rpm (CR 6.50:1)
O-435-A2 225 @2550 rpm (CR 7.50:1)
O-435-4 / O-435-K1 225 @3000 rpm (CR 6.50:1)
There are number of military versions that develop 255 hp @3400 rpm (CR 7.50:1)
