lycoming 0540
hillbilly540
lycoming 0540
Post by hillbilly540 »
Has anyone switched from stock to 10:1 pistons in their s/v and if so what differences were noticeable and also what fuel system will feed the bigger pistons the best .
14'2" wide nose gilileo I0540 s/v , 74" sensenich NGQ
dusty burch
Re: lycoming 0540
Post by dusty burch »
No change on fuel system it will give you more power but the bad thing is it will build more heat in your motor stick with stock it will last longer
lariat
Re: lycoming 0540
Post by lariat »
I did it and gained about 200 rpms once everything seated. My boat is a hunt boat, so I run it pretty hard from time to time and have not had any heat issues. I only run AV gas and did put a heat extractor shroud on it. I've checked my CH temps after running dry for over a mile in the summer and they were fine. Another thing I did though that may have made a difference is I had my pistons ceramic coated on top and teflon skirted. No change to my fuel system.
