which 540 cam
Kris_Moore
which 540 cam
Post by Kris_Moore »
Trying to decide on a cam for my new 540,I'm about to start pulling it down and gathering parts. I want something that will sound good and last. I have the stock tio-540 cam now, I've heard of people running the turbo cam, the phase 3 cam and the h290s. Which of those would give me the best sound and performance? Or is there something that would be better?
terrible ted
Re: which 540 cam
Post by terrible ted »
I would like a bigger- more hp cam to, I have vo 540. the solution is lighten the boat.
Packman
Re: which 540 cam
Post by Packman »
:thumbleft: :thumbleft: :thumbleft: :thumbleft:
terrible ted wrote:I would like a bigger- more hp cam to, I have vo 540. the solution is lighten the boat.
Re: which 540 cam
Post by kwanjangnihm »
Outlawaircraftengines
Re: which 540 cam
Post by Outlawaircraftengines »
Phase 3 is good. 290 sucks in my opinion. You can also get custom grinds on that turbo cam that work well.
Last edited by Outlawaircraftengines on Tue Jun 02, 2015 10:05 am, edited 1 time in total.
Gary Barber
Outlaw Aircraft Engines
www.outlawaircraftengines.com
863-698-0383
HAMMERHEAD
Re: which 540 cam
Post by HAMMERHEAD »
What is the downside to the h290?
Re: which 540 cam
Had some good, but more bad. Its a good mid range cam, but does not seem to allow much after 2500 for power. I have had several in a 540 where going from stock to 10:1 compression does not change rpm at all. The final staw on that cam for me was one I built about a year ago......you could pitch the 6 blade warp at 7,8, or 9 and the engine would only turn 2600. 9.5 it went down to 2500.
Gary Barber
863-698-0383
Kris_Moore
Re: which 540 cam
This engine will be 10:1, it's going to be just a play/ride boat motor. Going on a light 13' hull with light rigging and a saber or razr prop. I do plan on spraying it, I'll probably pitch it around 2900 and spray it to 3300. So Im looking for a cam that will give me performance but I want something that will sound good idling. Can the tio cam be ground without killing the lifespan of it? I normally deal with Larry at d&s but he doesn't like doing much other tHan the 290 grind because he can't say how long it will last.
midnight rider
Re: which 540 cam
Post by midnight rider »
Isn't the h290 grind the stock grind for gpu's. Hence why it falls after 2500-2600
gchuckie
Re: which 540 cam
Post by gchuckie »
I had a 10 to 1 540 av motor with a h 290 cam, I can say as for nitrous it loved it! It hit like a freight train on the bottle, I could gain 600 plus rpms on a properly sized tune. Now as for motor only it really sounded stock to me.
terrible ted
Re: which 540 cam
My builder loves the sound of the cam in my VO540. I don't think it thumps enough.
KR23
Re: which 540 cam
Post by KR23 »
I ran an h290 in my boat too. No juice, and she ran pretty dang good
Re: which 540 cam
Kris, put a phase 3 in it and you will be happy. I can get you a custom one ground but you will have to dial it, more trouble than its worth. lol
Gary Barber
863-698-0383
Bubba
Re: which 540 cam
Post by Bubba »
gchuckie wrote:I had a 10 to 1 540 av motor with a h 290 cam, I can say as for nitrous it loved it! It hit like a freight train on the bottle, I could gain 600 plus rpms on a properly sized tune. Now as for motor only it really sounded stock to me.
Mine loved it also up to 3300 rpm. Best nos cam I know of!
FLIRTIN WITH DISASTER
terrible ted
Re: which 540 cam
Outlawaircraftengines wrote:Kris, put a phase 3 in it and you will be happy. I can get you a custom one ground but you will have to dial it, more trouble than its worth. lol
I wonder what type of hp (torque) is available.
