UPDATED 6'' rigging move, too much?
jopete
Post by jopete »
well, apparently is isn't meant to be for me to put a trim tab on my deckover. amazon was suppossed to deliver it last tuesday, and it still ain't here.
so... i got to looking, and i think i will just move everything forward six inches and see what it does.
i was just wanting some opinions on if yall think a 6'' move is too much. i figure it can't hurt that wild bronco boat i got.
looks like i can just unbolt it and slide it forward then rebolt. will need to extend the fuel line to the tank and a couple wires going to the bieldge pump, but not much else. if it works i won't need the dang trim tab.
going offshore tomorrow or i'd be doing it right now.
Hog Wild
Re: 6'' rigging move, too much?
Post by Hog Wild »
I'd be cautious of moving things that far foreword. The boat has an issue with the bottom, and frankly there's very little that you will be able to do, short of taking it apart and re doing the bottom that will fix your hopping issue. A trim tab is probably your best bet short of a full reconditioning. That boat left Gary's shop riding flat and true. Years of pounding over who knows what has taken its toll. If I were you I would strip that boat down, yank the poly off and start examining the bottom. Re sheet it if you have to, and give that thing another 40 years of life. JMO.
Gary S
Post by Gary S »
It's probably the poly making it porpoise. Doubt that moving rigging will help. Can you shim the back of the poly down and make it act like a trim tab?
GeeLeDouche
Post by GeeLeDouche »
ah hell, give it a try! I don't think it will be as big of an issue as some of you think it will be.. We run a lot of weight in the front of our boats and they still run well.
Comanche-pup
Post by Comanche-pup »
I feel your pain, my old boat was horrible, a big O and damn, I could jump rope, I bought it that way, it was out of balance and the poly was jacked! check your bottom good, if the bottom is screwed, you are going to bounce
Post by One Eyed Gator »
Pm sent
CypressHunter
Post by CypressHunter »
Have you considered just moving your gas tank foward? Worked awesome on my cousin's old boat.... Hell he could of taken the trim tab off been just fine
dusty burch
Post by dusty burch »
Moving weight usually does not work to stop hoppingthe bottom of your boat is not straight need to work on your bottom
jopete
Re: UPDATED 6'' rigging move, too much?
Post by jopete »
another day in the love/hate relationship. lol
was sitting there making brackets to mount the trim tab on my boat, and couldn't make myself drill holes in it. lol
so......
i did like a wise man posted earlier and loosened up 3 screws holding on the teflon at the transom. then i looked in my scrap pile and found 2 peices of aluminum 1/8'' thick and about 1'' wide and 3'' long.
i slipped them in between the teflon and the bottom of the boat and screwed the screws back tight.
didn't look like much, but the boat runs alot better. got rid of most of the bounce. still gets squirrly after 2000 rpm's, but i'm rolling pretty good at that rpm.
i'll probly dig around and make 1 or 2 more peices and that should take care of it. at least till the teflon wears out, then i can fix it right.
ran the boat for 3 hours today in the heat, runs like a champ. nice to have extra power on tap compared to my stock gpu.
i took out the storage box in the floor. didn't look right. i might relocate the batteries to under the front. probly dangerous, but will clean up the lines on the boat!!!
thanks for all the help guys!!!!
Gary S
Post by Gary S »
It doesn't take a lot to do a lot.
