How to repair a crack in case oil leak
Seems I have a small oil leak, started taking pictures after I degreased it and found this crack,
Question is, can this be fixed, welded, or should it be just excepted and left as is?.
The crack is between the ring gear and the motor attach point, the picture is taken standing at the prop looking up at the
bottom.
Will this get worse?
Any help or ideas, what could have caused this?
Thanks
bottom.
Thanks
- John Fenner
- Southern Airboat Member
Re: How to repair a crack in case oil leak
Pan out and take a couple more pics so I can see what you are referring to
- Site Supporter - I
Aluminum or cast iron?
Did the magnet test and it is Aluminum, also I think I'll pull the prop off this weekend and get a look behind the ring gear to see where the oil is dripping from,
The bolts are in bad shape too, I think it time to replace the rubber on the engine mounts too, Thanks for looking...
What year, make, and model is that engine? Do you intend to pull it apart in order to fix it correctly? There are several ways to fix it but really one way to fix it right.Hardtail wrote:Did the magnet test and it is Aluminum, also I think I'll pull the prop off this weekend and get a look behind the ring gear to see where the oil is dripping from,
- Contact:
I can fix your oil leak give me a call probably going to split the case to do it right 352-258-4910 Dusty
- air-roberts
- Site Supporter - IV
yea if you split case then you can tig it with no prob
Air-Roberts
New & Used PROPs
WhirlWind prop dealer
New & Used PROPs
- MYDIXIEWRECKED
Been there, Done that. Definitely can be done.
THOUGHT FOR THE DAY
Lifetime member NRA
Lifetime member NRA
What is the current condition of your oil leak?Hardtail wrote:Seems I have a small oil leak, started taking pictures after I degreased it and found this crack,
bottom.
Thanks
I changed the bolts in the engine support by the starter, the one closest to the prop seemed not to tighten so I put some Teflon tape on the threads and got it to tighten, and now no leak, the picture I took looked like a crack at that angle, when I pulled off the prop, I cleaned the oil off and that line is a contour in the case.
Thanks for the help,
