Triggering an MSD Box with Points
gblack15
Post by gblack15 »
I am replacing the siamese mag on my 0-360 H2AD with an MSD system. Looking for a way to trigger my msd box and considering using the points, anyone ever ty it? Lots of talk about it on the sprint car pages. They claim triggering from points works great, my thoughts are to use one side of the mag as normal and run the other set of plugs on a box similar to the way the Aircraft guys do it. Also lookng for recomendations on what coil packs to use.
I know there are a lot of new solutions out there but I just cany bring myself to pay $1600 for a 4cl ignition system that I am sure I can build for much less.
odcjohn
Re: Triggering an MSD Box with Points
Post by odcjohn »
http://www.msdignition.com/uploadedFile ... ctions.pdf
read you should be able to never done on a av motor but plenty of points cm
