Starter part number or application
twister69z
Post by twister69z »
I have what I believe to be a innovative accessories starter kit . It uses a lycoming 149 tooth ring gear on a aluminum hub. What is the application or part number of the starter used on this kit?
Help me please, the alternator is a nice lightweight flat belt . This is on a sandcast O-470 continental.
Twister69z
Davie GSO480
Re: Starter part number or application
Post by Davie GSO480 »
Does it look like this??
http://www.airtecinc.us/airboat.html
Proud member of the Airboat Association of Florida.
A Miami Landmark sense 1951
http://www.aaof.com
twister69z
I will try to post a picture or two of the old broken starter and bracket.
No it don't look like any pictured in that link.
Twister69z
twister69z
Here are a few pictures, it is a 149 tooth Lycoming ring gear.
airjohn81
Post by airjohn81 »
if it's an 11 tooth bendix gear (i just went through this) that is a mid 80's chrysler K car starter.. go to napa an they can show you the picture of it .... thats the exact starter i just replaced 2 days ago on my gpu.. hope it helps... but that not a toyota... terminals on the wrong side
:old_glory: :florida: :rebel:
twister69z
Thanks !
Fat Cat
Post by Fat Cat »
Call Norman Clay at Innovative Accessories. That looks like one of his starters. The Chrysler may bolt up but probably won't have as much torque as Normans. (863)357-3400.
13ft Mamba hull
Gary Armstrong 540 UpStack
