looking for a good mechanic !!!
mrbill
Post by mrbill »
looking for a good lycom 0540 mechanic in the central fl area ?
mojoe
Re: looking for a good mechanic !!!
Post by mojoe »
With most things, you have 3 choices: fast, good and cheap.
Unfortunately, you only get to pick 2.
With ac mechanics, you only get to pick one, chose wisely!!
You know my recommendation.
Mark 7:9
rredneckn
Post by rredneckn »
Moores aircraft 407-422-4318
Post by kwanjangnihm »
Jurnigan Engines & Parts
1003 Pleasant Acre Drive
Plant City, FL 33566
Phone: (813) 752-9214
:rebel:
mojoe
Post by mojoe »
rredneckn wrote:Moores aircraft <a href="tel:407-422-4318">407-422-4318</a>
You do know my recommendation :cheers:
Mark 7:9
flshooter
Post by flshooter »
My vote and my boat goes to JD when it's got a problem
IO-520 72"Q series on a hawk step
Waggs
Post by Waggs »
Wally Moore, hands down
Liberty Mechanical Services
321-689-7709
Making America Cool Again!
KCCO
fladan
Post by fladan »
flshooter wrote:My vote and my boat goes to JD when it's got a problem
Ditto
trailerdon
Post by trailerdon »
All good choices. After several bad past experiences with other mechanic's, Jurnigan is the only place my boat goes.
mrbill
Post by mrbill »
thanks guys once again i did not go to some one new i took it to wally and him and his boy found the problem i had a bad valve causing low power and a miss unfortunately i got it to him a little late the cyl could not be saved so a new one goes on !!! Wally is the man!!!!!!!!!
