Supercharger boost pressure
Dirtman
Post by Dirtman »
Can anyone tell me the normal range for boost pressure on a supercharged Lycoming
jerryncypret
Re: Supercharger boost pressure
Post by jerryncypret »
I've seen about 15 to 18 psi
Quick Draw
Post by Quick Draw »
All of the ones I've ever seen was 14 to 15 psi at 3400 rpm on a gso. I drove Farmboy's boat a couple months ago and his was laying a 20psi gauge in the corner. I don't know if his gauge is broke and he didn't have a tach so I don't know at what rpm.
farmboy
Post by farmboy »
My gso is 15psi at 3400 rpm's.
farmboy
Post by farmboy »
Quick Draw wrote:All of the ones I've ever seen was 14 to 15 psi at 3400 rpm on a gso. I drove Farmboy's boat a couple months ago and his was laying a 20psi gauge in the corner. I don't know if his gauge is broke and he didn't have a tach so I don't know at what rpm.
Gauge must be broke... :scratch:
SkinnerBack
Post by SkinnerBack »
I think Farmboy is hiding something tricks up his sleeve!!! Lol
Dirtman
Post by Dirtman »
Thanks for the replies guys, was told several different things by guys who didn't own a GSO engine but had a friend of a friend kind of thing. Glad to get some good info. Hopefully the boat will be ready for the Broward show its been a long time coming
farmboy
Post by farmboy »
SkinnerBack wrote:I think Farmboy is hiding something tricks up his sleeve!!! Lol
Not me :headbang: :lol:
farmboy
Post by farmboy »
Dirtman wrote:Thanks for the replies guys, was told several different things by guys who didn't own a GSO engine but had a friend of a friend kind of thing. Glad to get some good info. Hopefully the boat will be ready for the Broward show its been a long time coming
RPM's changes everything... If every motor turned 3400 every one should make 14 to 15 psi cause there all made with the same parts unless the charger has had work done to it...
444kyle
Post by 444kyle »
where do yall pull the psi from. Hook a gauge to the boost ref. line for the carb?
14ft JB Hull,Lycoming GSO480,10 blade warp drive
Dirtman
Post by Dirtman »
Kyle hopefully Kevin will see this and chime in. I was intending on running the boost pressure gauge off the port at the bottom of the piping running from the supercharger to the plenum the intake tubes come out of
TIGO541
Post by TIGO541 »
Yes there is a 1/8npt in the intake to hook the gauge to. Some have one on both sides
13-6x7-6 Hamant Ultra-lite,Custom TIG Stainless rigging,1.7 Rotator,Supercharged 480,Electronic Ignition,80 inch 3BLD R,B&S trailer
TIGO541
Post by TIGO541 »
444kyle wrote:where do yall pull the psi from. Hook a gauge to the boost ref. line for the carb?
This you can do also yes
12PSI
Post by 12PSI »
Before I had enough prop to hold it back, my 540 would peg a 25lb gauge.
