540 ?
DWAdiesel
540 ?
Postby DWAdiesel » Thu Dec 31, 2015 5:07 pm
I found a Lycoming 540 on an old air gator. the id plate says o-540 B2B5. 235hp at 2575. I'm looking to build a new boat with this engine so was wondering what it is worth in running but old condition, planning it needs overhauled.
also want to know
1rough cost to overhaul.
2 if it can be built up closer to 300hp.
3 how complicated it is to overhaul, I'm a marine diesel tech. and build engines every day but have 0 experience with ac engines
4 it has the special alen nuts on the cylinder flange so I think that is a narrow deck?
any info is appreciated
SkinnerBack
Re: 540 ?
Postby SkinnerBack » Thu Dec 31, 2015 6:02 pm
Well cost of overhaul, all depends on how far you go into it. I just rebuilt my motor with some help of a few friends & had roughly $7k in it. That was turning the crank new cam new bearing new cylinders new Pistons & electronic ignition........ Yes the acorn nuts need a special cylinder wrench & yes it's a narrow deck. These engines are pretty simple inside, well it was when you had people around that have been in them many times before!!
terrible ted
Re: 540 ?
Postby terrible ted » Fri Jan 01, 2016 12:47 am
wrenches are on line from air craft supply houses
mwood7800
Re: 540 ?
Postby mwood7800 » Fri Jan 01, 2016 2:06 am
When I did my e4b5. All I did was the top end, it was around 5k with the mags.
