220 carb holley 500
jeepinocala1111
220 carb holley 500
Postby jeepinocala1111 » Sun Feb 21, 2016 3:13 pm
Anyone ever try a holley 500 made for circle track racing? My 2 barrel holley 500 works good but since my rebuild of everything else I am wanting a new carb its pretty much the only thing I have not replaced and I have to wonder if ill get a bit more from a race ready carb?
glades cat
Re: 220 carb holley 500
Postby glades cat » Sun Feb 21, 2016 3:20 pm
I had a Holley 500 on my GPU and it ran well. The only thing you need to do is install some 74 size jets, a 10.5 power valve and get a cyl temp kit and gauge to keep an eye on things. I wouldn't get anything "race ready". By new and do the simple jet & power valve mods.
jeepinocala1111
Postby jeepinocala1111 » Sun Feb 21, 2016 3:21 pm
jeepinocala1111
Postby jeepinocala1111 » Mon Feb 22, 2016 6:31 pm
glades cat wrote:I had a Holley 500 on my GPU and it ran well. The only thing you need to do is install some 74 size jets, a 10.5 power valve and get a cyl temp kit and gauge to keep an eye on things. I wouldn't get anything "race ready". By new and do the simple jet & power valve mods.
Did your motor have dome top high compression pistons?
Comanche-pup
Postby Comanche-pup » Mon Feb 22, 2016 6:50 pm
Mine was set up just like Glades cat wrote, and yes mine had domed topped pistons and double magged
jeepinocala1111
Postby jeepinocala1111 » Mon Feb 22, 2016 7:19 pm
Comanche-pup wrote:Mine was set up just like Glades cat wrote, and yes mine had domed topped pistons and double magged
Holley is recommending a 350 cfm 2 barrel
glades cat
Postby glades cat » Mon Feb 22, 2016 8:29 pm
It'll breathe better with the 500. The GPU is a relatively large displacement engine.
6 cylinders with a 5" bore displacing 470 cu.in. will produce a strong signal through those 2 throttle bores.
jeepinocala1111
Postby jeepinocala1111 » Mon Feb 22, 2016 8:31 pm
glades cat wrote:It'll breathe better with the 500. The GPU is a relatively large displacement engine.
I am leaning towards this carb.
https://webapi.holley.com/products/fuel ... /0-4412BKX
12PSI
Postby 12PSI » Tue Feb 23, 2016 1:01 pm
That is one sharp looking carb.
lotacarnage1
Postby lotacarnage1 » Tue Feb 23, 2016 3:32 pm
would this carb be too much for a healthy stock single mag 220?
http://www.jegs.com/i/Holley/510/0-1850 ... gQodczILbw
Holley 0-1850SA - Holley 600 cfm Aluminum Street Carburetors
smeller's the feller
glades cat
Postby glades cat » Tue Feb 23, 2016 4:17 pm
Not a big fan of the Holley 4160 series carbs. The GPU just runs better without the 4 bbl transition. Two barrels at 500 cfm's is consistent and smooth from idle to max RPM, and it is a 4150 style carb. 500 CFM's is over-carbed by about 150CFM's already.
Postby John Fenner » Tue Feb 23, 2016 4:56 pm
My 220 conversion has a modified 500, I put annular discharge boosters in it from an 80s Mustang 5.0ho carb with 75 jets and a power valve block off plug. A stock PE150 will run fine with an out of the box unit but tuning is recommended as Glades Cat suggests.
jeepinocala1111
Postby jeepinocala1111 » Thu Feb 25, 2016 7:20 am
Well I went with the 500 2 barrel ultra I figured what the hell.
Postby One Eyed Gator » Thu Feb 25, 2016 12:29 pm
Pm Sent
Users browsing this forum: Google [Bot], needcoffee and 10 guests
