Alternator
digginfool
Alternator
Post by digginfool »
Can anybody tell me make and model of the small alternator that's used? Schmidt is sold out and I need one. I've heard it's off a Kubota tractor but there's got to be more info than that. The Kubota dealer said without part number, they can't help; they use about 50 different alternators.
digginfool
Re: Alternator
406 JAMIE wrote:Look at middle pic there is a #number wright there by where it bolts to bracket at top and goggle it to see what u have.it starts with A .
Tried that. Nothing came up.
deepsea diver
Re: Alternator
Post by deepsea diver »
It is used on lots of equipment,tractors and fork lifts.
WPS alternator Caterpillar
Track loader 931c 12192
Air teck has them (DICK Waters)
Norman Clay has them
Bro ward alt and starter or Miami alt and starter has them.
Good luck
Re: Alternator
Post by John Fenner »
Greg, take it to Davie battery, they can fix it fast.
deepsea diver
Re: Alternator
Go online to Miami alternator and starter.com
Then to alt
Then to industrial
Then look at cat or kobota
305-593-0560
You should be pooping in tall cotton, brother.
V/r DSD
lorick
Re: Alternator
Post by lorick »
innovative accessories inc. norman clay 863-357-3400
marshrat
Re: Alternator
Post by marshrat »
My airtec went bad got the same one from auto zone
Part # 14946 and it was a bit cheaper!!
Jim
Team ChugMonkey Drink Hard or Go Home
14x8 DB with Ls Power :naka:
Strangiato
Re: Alternator
Post by Strangiato »
Just went through the mystery alternator process myself. Previous owner powder coated over all numbers. Went to advance auto parts. If you find a guy whose worked at an auto parts store for a while they can usually find a match. They see alot and the computer shows a pic. Good luck.
Bdriller
Re: Alternator
Post by Bdriller »
that's the same alternater I run on everything including airboats cost is minimal ,hell I tried to find the name for you apparently its a hidden trade secret ive got part number if that will help?
digginfool
Re: Alternator
So, ended up not being the alternator. We were having fueling problems and the engine builder installed a mechanical fuel pump and disconnected the electric pump fuel lines but not the electric lines. Little did either of us realize the self-exciter line came off the fuel pump switch. Not wanting to run the pump dry (or listen to it) I never turned the fuel pump on. Eventually, battery died and left me stranded. Since the SE wire was dead, when I used the voltmeter to test, alternator wasn't putting out. After a bench test proved the alternator wasn't the problem, it took me just a couple minutes to figure what happened. Cut the wire to the fuel pump until I need it and now when I turn on the fuel pump switch, I have an alternator that works. Doh!
