O-470-11 help
aluminumwelder0073
O-470-11 help
Post by aluminumwelder0073 »
first time on the site and trying to buy my first boat. I am looking at a O-470-11 boat. I would like some info on what the oil pressure should be at idle and hot. Any other info would be a great help.
thanks
jeepinocala1111
Re: O-470-11 help
Post by jeepinocala1111 »
aluminumwelder0073 wrote:first time on the site and trying to buy my first boat. I am looking at a O-470-11 boat. I would like some info on what the oil pressure should be at idle and hot. Any other info would be a great help.
thanks
Just give your location and possibly someone from the forum with a lot of time with that engine will help you out.
lilly-Pad
Re: O-470-11 help
Post by lilly-Pad »
thanks
2X Welcome to SA :cheers:
12 ft Don Davis / 0470 conv / 68 NGQ , A.A.O.F member
Best laid plans of mice and men, wont always get you laid.............
aluminumwelder0073
Re: O-470-11 help
I live in Okeechobee
dshaw94
Re: O-470-11 help
Post by dshaw94 »
I believe the book calls for a min of 13 pounds, hot at idle.
We all got it coming, kid. (William Money)
Re: O-470-11 help
Post by kwanjangnihm »
Here are a few tips:
1. Take an experienced airboat person with you to check it out.
2. Take the boat out and run it for over an hour to check temps, oil pressure, tach, vibrations, etc.
3. If it passes these tests, take it to a qualified aircraft mechanic and have a leak down check done and a good once over on the engine, carb & mags.
Even if #3 costs you a couple hundred bucks, its worth it in the long run. Airboats are money pits!! You pay to have fun. :toothy7:
Good luck and welcome to SA. :rebel:
aluminumwelder0073
Re: O-470-11 help
Thanks for the help and for the welcome to SA. I will post an update when the deal is done.
jeepinocala1111
Re: O-470-11 help
aluminumwelder0073 wrote:Thanks for the help and for the welcome to SA. I will post an update when the deal is done.
I would not get it if the oil pressure is lower then 40 cold or lower then 40 hot that sounds too low Mine is 55 to 60 cold 45 to 55 hot. And I think that is kinda low.
aluminumwelder0073
Re: O-470-11 help
Thanks jeep has your 11 been a reliable engine for you. I heard some low rumble about it's reliability.
aluminumwelder0073
Re: O-470-11 help
Anyone else have a 470-11 that mite have a few tips on that engine.I just don't want to get burnt on this.I have read enough horrible stories I don't want to live one.
JT540
Re: O-470-11 help
Post by JT540 »
they don't need that high of oil pressure. min 20 is good for a continental hot idle. you will see some engines that are running as low as 10 psi at ide and still fine. some of the old e- series are most notorious for that. look up engine specs online and you can find almost anything you need to know. google is the best tool you have if you use it.
jeepinocala1111
Re: O-470-11 help
aluminumwelder0073 wrote:Thanks jeep has your 11 been a reliable engine for you. I heard some low rumble about it's reliability.
I have a gpu but 20 psi oil pressure seems way too low. The -11 I have been told to stay away from.
Re: O-470-11 help
http://www.southernairboat.com/pdf/airc ... ental/470/
the O-470-11 is listed here - open the pdf and it has oil pressure and operating temps
:rebel:
jeepinocala1111
Re: O-470-11 help
kwanjangnihm wrote:http://www.southernairboat.com/pdf/airc ... ental/470/
:rebel:
I am VERY surprised oil pressure at idle shall be at least 10 psi at idle and oil pressure shall be 40-75 psi at speed above 1500 rpm.
You could never get me to buy any engine with oil pressure at 10 psi at idle is this will all 0470 engines?
Planeguy
Re: O-470-11 help
Post by Planeguy »
I thought the 10 psi sounded low too but it is what the manual says. The odd thing for me is the document used to certify the O-470-11 for aircraft shows 30-60 psi with no note for a lower hot idle while the 470's that have a letter behind them do have the 10 psi note.
http://rgl.faa.gov/Regulatory_and_Guida ... v%2016.pdf
jeepinocala1111
Re: O-470-11 help
Planeguy wrote:I thought the 10 psi sounded low too but it is what the manual says. The odd thing for me is the document used to certify the O-470-11 for aircraft shows 30-60 psi with no note for a lower hot idle while the 470's that have a letter behind them do have the 10 psi note.
A good friend of mine is a certified ac mechanic this must be why he told me to stay away from certain engines. I wonder what the tear down inspection time on one of these engine is when in a plane?
Planeguy
Re: O-470-11 help
Post by Planeguy »
I don't have any experience with the 470 but based on this document I would guess it is recommended at 1500 hours.
http://www.tcmlink.com/pdf2/SIL98-9E.pdf
Bruce
Re: O-470-11 help
Post by Bruce »
if its got around 20-25 psi at idle hot its good to go
12 foot Mamba "The Underdog"
dshaw94
Re: O-470-11 help
Post by dshaw94 »
Whats the deal with folks giving there opinions to questions like " what's exceptionable oil pressure for an o-470-11"!!
The answer to the question is what the manufacturer "TCM" Says it is! Not your uneducated professional opinion about how much oil pressure a motor would need for you to buy it or what your AP buddy told yeah once.
When you start engineering, warranting, and federally certifying engines for flight the you can dictate the proper oil pressure parameters for that engine. Until then lets stick to the manufacturer specifications.
Planeguy
Re: O-470-11 help
Post by Planeguy »
dshaw94 wrote:Whats the deal with folks giving there opinions to questions like " what's exceptionable oil pressure for an o-470-11"!!
Which specs do you use? The numbers in the Army's overhaul manual from 1960 or the numbers in the Type Certificate from 2011? They both come from TCM.
BANANA BOAT
Re: O-470-11 help
Post by BANANA BOAT »
Did you buy it?
I have a, -11
I have figured out how to make mine have good oil pressure and never tap
chucky7
Re: O-470-11 help
Post by chucky7 »
how did you make it have good oil pressure? I just bought one and it seems to be leaking a little oil from the push tubes, i went through 3 quarts sunday
jopete
Re: O-470-11 help
Post by jopete »
throw some lucas oil stabilizer and lucas oil stop leak in that beech and roll it. that's what i do.
overthinking things used to stop me from enjoying my airboat. now i fix the big things and enjoy the ride.
good luck.
Seminole Red
Re: O-470-11 help
Post by Seminole Red »
My O-470 has about 65 hours on a fresh build. I am using 9 quarts of Phillips Aviation 20W-50 oil. My pressure is around 60 psi cold and 40 psi hot. I am not an expert by no means, just doing what Lacey Everett told me to do.
Seminole Red
If You're Out of the Throttle, You're Out of Control
BANANA BOAT
Re: O-470-11 help
do no fill it up all the way.
I only put in 7
Sent from my SAMSUNG-SM-N900A using Southern Airboat mobile app powered by Tapatalk
