Spark plug torque specs
JPerkins323
Post by JPerkins323 »
Changing spark plugs on my 0540 today. What do I torque the plugs to? Thanks in advance.
"BUZZ KILL"
12x6.8 .090 thousands 1/2 deck hunt boat with .125 backup plates and a lil' sheet of stainless. 0540 s/v spinning 5 blade sabers.....Ready to party.
Built by D&E Metal works in Homestead, FL: (786) 412-9018
Re: Spark plug torque specs
Post by kwanjangnihm »
420 in.-lbs. (or 35 ft.-lbs.)
just changed mine out and torqued to 35ft-lbs - used new copper crush washers (+ a dab of never seize)
:rebel:
JPerkins323
Awesome thank you sir
"BUZZ KILL"
Planeguy
Post by Planeguy »
New gaskets are a good idea. Assuming you are using these: http://www.aircraftspruce.com/catalog/e ... ckkey=4531
The old ones can be softened and reused by heating them until they glow and quenching them in water (copper works just the opposite of steel).
mojoe
Post by mojoe »
I have a set of those washers on order. Should I leave the little washers that come on the plugs or remove them an install just the copper washers?
Thanks
Mark 7:9
Planeguy
Post by Planeguy »
mojoe wrote:I have a set of those washers on order. Should I leave the little washers that come on the plugs or remove them an install just the copper washers?
Thanks
Sorry, I made the assumption you were using aircraft engine plugs. They would have come with the copper washers. Someone with automotive plug experience will have to field that question.
Gary S
Post by Gary S »
I had to use the copper on a 0320 because with out them the plugs leaked. They are better and yes you have to take the aluminum washers off. I use a pair of dykes to do it. Or should I say a pair of diagonal cutters?
mwood7800
Post by mwood7800 »
Champions work with the regular washers on my 540. I tried some denso without the copper washers and burned up 2 new cylinders. I swap out the champ d16 once a year only because they get rusty.
