Spark plug?
highlife57
Spark plug?
Post by highlife57 » Fri Apr 22, 2016 8:06 pm
How do you get a broken spark plug out?Image
Gary S
Re: Spark plug?
Post by Gary S » Sat Apr 23, 2016 5:28 am
That one's bad.
Sorry I didn't read second post. Only thing I can suggest is a screw extractor. You might take the helicoil
With it .
highlife57
Re: Spark plug?
Post by highlife57 » Sat Apr 23, 2016 7:12 am
Should I put some heat on it?
Gary S
Re: Spark plug?
Post by Gary S » Sun Apr 24, 2016 6:11 am
I think at this point you have to try whatever you can think of. I believe I would use some acetone and transmission fluid on it for a while first. Maybe some heat with the fluid. Your going to have to take your time.
Planeguy
Re: Spark plug?
Post by Planeguy » Sun Apr 24, 2016 9:52 am
I agree with Gary. Soak it with a 50/50 mix of acetone and tranny fluid for a couple of days then try a screw extractor. Helicoils are easy to replace if the head doesn't get messed up. The biggest concern for me would be keeping (or flushing) the trash out of the cylinder.
junglecat
Re: Spark plug?
Post by junglecat » Sun Apr 24, 2016 11:24 am
Probably a lot easier to pull jug . If anything (trash) gets in it then you have bigger problems.
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
HAMMERHEAD
Re: Spark plug?
Post by HAMMERHEAD » Mon Apr 25, 2016 7:19 pm
I would take the extra 10 minutes to pull the cylinder. Aerkroil penetrant and heat.
HAMMERHEAD
Re: Spark plug?
Post by HAMMERHEAD » Mon Apr 25, 2016 7:21 pm
On second thought by looking at the plug you will probably break off every exhaust stud. Good luck!
