Need help identifying
rebel2wolf
Post by rebel2wolf »
I need to replace a cylinder on my boat, but am not sure which one it is. I was told that the motor was a Lycoming 170 when I bought it, but that is all I know. Any help would be great. :rebel: :rebel:
JT540
Re: Need help identifying
Post by JT540 »
those are 480 cylinders your motor is a 320 with 480 cylinders people call them 170s
rebel2wolf
Thanks for the info. Any idea where I can find one?
Try Gary Barber at Outlaw Aircraft he is a great place to start.
863-698-0383
JCGator
Post by JCGator »
I've gotten 480 cylinders from Gary and he is great to work with. He is located in near plant city/lakeland. I've picked up parts at his shop and also had them shipped COD.
out of curiousity... how do you know you need to replace a cylinder but don't know which one? Also is it common to run hose for the oil return lines? A couple of my original aluminum ones leak a little and im curious if theres any reason not to just replace with hose :dontknow:
10'6" Taylor Hull. Lycoming 170 hp - O-320 w/ 480 AV jugs
rebel2wolf
I know which cylinder, just wasnt sure what cylinders I had on the motor. I didn't think the 480's were angle valve. My jugs are angle valve.
JCGator
Post by JCGator »
480's are angle valve. Gary had me send him a pic of the cylinder because i guess there are two types with a small difference.
rebel2wolf
Awsome. Thanks for the info.
