broke exhaust stud
lanny haff
broke exhaust stud
Post by lanny haff »
Can anyone give me any pointers on getting a broken exhaust stud out i tried heat n vise grips no luck thanks lanny
hogdoggin
Re: broke exhaust stud
Post by hogdoggin »
Is there enough sticking out that you can weld a nut on it? I've had luck doing this before. The heat from welding seems to help free it up.
helicsher
Post by helicsher »
Use a easy out ?
"Success Requires No Excuses"
GMAC 76
Post by GMAC 76 »
hogdoggin wrote:Is there enough sticking out that you can weld a nut on it? I've had luck doing this before. The heat from welding seems to help free it up.
X2
rjfjr
Post by rjfjr »
X3
pax1ton
Post by pax1ton »
an old exhaust trick heat the stud,and take a candle put it on the edge of the stud and let the heat draw the wax into the threads, if done correctly ,it will come out as easy as can be.
jeepinocala1111
Post by jeepinocala1111 »
lanny haff wrote:Can anyone give me any pointers on getting a broken exhaust stud out i tried heat n vise grips no luck thanks lanny
This is the absolute best way you get some Kroil put it on as much as you can het the stud with a pencil torch lighter put more Kroil on it if you are careful enough with the lighter you will see the Kroil going right up into the threads that stud will unscrew with a pair of needle nose pliers. Ask me how I know this trick. IT WORKS.
Kroil is awesome worth a try before anything
Candle trick does work most times but gotta get it real hot
I would Kroil first then weld nut after that
lanny haff
Well i had billy kline fix my broken exhaust stud and a new rear seal great guy all I can say so last night I took the boat out it had a problem ideling so i took it out to see if it would clear up no luck ran fine at regular speed well i shut it off disconnected the water seperator n it cleared up after a few i frogged til 4:00a.m fine no problems started to head back to landing and lost power would not go past 1800 rpm could this be carb related or mags n plugs n wires never have been changed either
lanny haff
Boat sat a year n half prior but started right up n ran fine on trailer
jeepinocala1111
lanny haff wrote:Boat sat a year n half prior but started right up n ran fine on trailer
Yeah sounds like the problem is when you disconnected that water seperater the water just went straight to the carb :slap:
lanny haff
No water in my gas tank i drained and cleaned it out. Before i left but did not replace the water separator thats why i bye past it out in the swamp n drained the carb bowl
lanny haff
No water in my gas tank i drained and cleaned it out. Before i left but did not replace the water separator thats why i bye past it out in the swamp n drained the carb bowl and when i started it up after sitting the fuel line straight from fuel pump was put in a gallon can to prevent trash pickup
Raizincane
Post by Raizincane »
Clean all your plugs.If you idle around a long time "frogging"your plugs will foul
