0540 narrow angle valve issue
Cooter69
Post by Cooter69 » Wed Jun 15, 2016 10:20 pm
So I was riding last Saturday and had and issue with my motor, had bad vibration and when I stopped I had 4 studs broke on #5 cylinder 3 of the 3/8 ones and 1 of the 1/2 thru studs. My question is how does the thru stud come out ?? We where able to get cylinder off and no other damage except the studs. My guess is nuts came loose and caused this to happen, but need to get thru stud out to and measure and order correct part.
All advice is welcomed !!
Cooter
:proud:
:rebel:
Crazy Cooter
USMC
14 " Seminole SS rigging with 0540 Angle valve 6 blade warp drive.
JT540
Re: 0540 narrow angle valve issue
Post by JT540 » Thu Jun 16, 2016 7:06 am
you will probably have to pull the cylinder opposite from it and the stud will thread out but it will be a pain to do wile the case halves are together.
Cooter69
Post by Cooter69 » Thu Jun 16, 2016 10:42 am
Thanks jt540 !! It is coming out the side of #5 and lycoming tech said use a slide hammer and it will come on out as well. Will have to wait and see and get back to you.
Thanks
Cooter
:proud: :rebel:
Crazy Cooter
USMC
twister69z
Post by twister69z » Thu Jun 16, 2016 11:12 am
NO on the slide hammer , narrow decks have screw in thru studs , wide decks have drive thru through studs!
Twister69z
twister69z
Post by twister69z » Thu Jun 16, 2016 11:13 am
Twister69z
mwood7800
Post by mwood7800 » Thu Jun 16, 2016 7:27 pm
My 540 did the same thing a couple years ago, call Jurnigan for info on which way it comes out, mine screwed out the same side as the broken stud and I only had to take off 1 cylinder and the opposing nut on the other side. Jr had a stud, I had a local machine shop make me a couple out of harder steel.
