Shutdown proceedure for IO520
I would like to know what the proper shut down procedure is for a fuel injected Continental 520. I have a switch for the fuel pump, fuel cut-off and a switch for each mag. I have been told that once I am running, I can turn off the fuel pump so if I remember, I do. The problem I am having is that is just wants to keep on running and sometimes backfires and runs backwards before it stops. I know this can't be good, so I am wondering what I need to do so it STOPS when I want it to.
I have tried shutting off the fuel cut-off switch and wait for it to quit, but it seems to linger on and keeps running. In desperation, I turn off both mags and it still wants to go until it starts to cough or run backwards and I turn the mags back on (and it runs) and then back off. I just can't seem to find the right combination to stop the motor in what I think is in a healthy way every time I want to stop. Any ideals?
- digginfool
- Site Supporter - III
Re: Shutdown proceedure for IO520
Two things come to mind. First, when you get to where you want to stop, do you let the engine run for a few minutes at idle to let it cool down? Second, are you running avgas? Running mogas will make the engine run hot and can also create the issue you are describing. Apparently, you are running an injected motor but both of these conditions can cause a carbureted motor to Diesel and, you're right, it's not good for the motor. I've no experience with injected AC motors but I would imagine that if the engine is hot enough and there's fuel in the lines it could get enough to Diesel on after you shut off the mags.
If the lean out is adjusted properly to cut off the fuel then pulling the cable for the lean out should cut off the fuel and the engine should shut down on its own and then you shut off the mag switches. That is how mine works anyway. Sounds like the cable for the lean out might not be shutting fuel flow off completely. If its possible with the engine ideling move the lean out lever by hand to the completely off position and see if it shuts down any quicker if so just adjust the cable, if not possibly fuel is getting by the lean out and there is a problem in the barrel valve. If you find you have a problem bypassing fuel past the barrel valve, Joey aka Qwikdiesel is in Melbourne and he really knows his stuff on fuel injection systems
- Southern Airboat Member
He never mentions the lean out - does it have one?
I agree with Dirtman and Digginfool, if it is dieseling then you are still getting fuel into the cylinders. Assuming you are using the stock injection system... are you using the mixture cutoff on the fuel servo (throttle body) or a cutoff in the line somewhere? Just killing the pump would still allow some fuel to be pulled to the engine and a remote cutoff could do the same. The best way to shut down would be to tun the pump off and move the mixture control to the cutoff position (again, assuming stock setup) then turn off the mags after engine stops.
Digginfool also had a good point about the heat and fuel type.
- Site Supporter - VII
I use an electric fuel solenoid in the fuel supply line to the manifold valve, the solenoid is powered thru a toggle switch to turn it on/off. Turn it on to allow fuel thru it to the manifold valve and turn it off to stop the fuel to the manifold, the engine will shut off clean with in 2-3 seconds every time.
Another question would be... are you sure the mags are shutting off? Just because the switch is off doesn't mean they are grounded. They won't fire if they are spinning backwards but if they are sparking and still getting a little fuel it will act like it is dieseling.
First off, thanks for the response! To clarify, it is fuel injected so no carb and I do have an electric fuel solenoid in the fuel line before the manifold. I do use 87 octane pump gas and have 8.5 pistons. The top end is fresh with new pistons/rings/valves and 53 hours on the clock. The injection system was just overhauled and the fuel solenoid is new. Pretty much a new motor.
I have tried letting it run for a few minutes before shutting down, but still have the same run-on problems. Like schmidtav2 said, I thought once I shut off the fuel solenoid, it would stop within a few seconds. As far as it getting hot, I just ran the motor for three minutes in the yard to load it back up on the trailer and have the same symptoms as if I ran for 30 minutes in the swamp. I have done a mag check recently by shutting one off at a time and the rpm's dropped a few hundred each time so I'm assuming they are okay. Oh, new switches, gauges and wiring throughout.
Is there an adjustment on the injections system to make it leaner or richer? Maybe it's to rich?
There is your problem too low of a octane.
- digginfool
If you're not going to run avgas (which you should), at least run the highest octane fuel you can find. 87 is disaster waiting to happen. AC motors were designed for the slow burn of high octane fuel. Low octane fuel burns hot and fast. Plus, with the high heat of air cooled engines, the low octane can, and most likely will, cause detonation which will destroy your motor.never enuff wrote:There is your problem too low of a octane.
Proper shutdown, pull rich lean cable to full lean ,after engine quits both mag switches to off( grounded)
if engine tries to run on or diesel after going to full lean , its an adjustment problem at the barrel valve,(fuel not getting completely shut off)
on a side note fuel octane would have nothing to do with the problem, its just not shutting the fuel supply off completely
- HAMMERHEAD
Fuel would absolutely make the engine run backwards! The shut down procedure for an airplane isn't always practical for an airboat. For example you are idling up to other boats or a dock and you want to stop close. You can't pull a lean cable and wait for the engine to shut down. Wether it be proper procedure or not I have always shut the motors down with the mag switches. Not to mention the likely hood of forgetting to shut the mag switches off when shutting down with fuel. Just my two cents.
- digginfool
In the case of an injected motor, octane rating may not have anything to do with the Dieseling issue but everything else is true; if you're not running avgas, you should run the highest octane you can find.pax1ton wrote:Proper shutdown, pull rich lean cable to full lean ,after engine quits both mag switches to off( grounded)
Thank you for all the input. My first move will be to try 93 octane and if that doesn't fix the problem then I'll try avgas. I appreciate all the help!
Fair enough response, The only thing that should be added ,when shutting down with the mag switch and not the rich lean handle,HAMMERHEAD wrote:Fuel would absolutely make the engine run backwards! The shut down procedure for an airplane isn't always practical for an airboat. For example you are idling up to other boats or a dock and you want to stop close. You can't pull a lean cable and wait for the engine to shut down. Wether it be proper procedure or not I have always shut the motors down with the mag switches. Not to mention the likely hood of forgetting to shut the mag switches off when shutting down with fuel. Just my two cents.
one must remember that theres burnable fuel left in the cylinders ,and if a mag switch or wiring would go bad, it could leave ya with a hot mag .
any movement of the prop could cause the engine to fire.
I am not really an airboater yet but can that extra half second at idle really be that big of a deal? It seems to be it wouldn't be hard to get use to.HAMMERHEAD wrote:... The shut down procedure for an airplane isn't always practical for an airboat. For example you are idling up to other boats or a dock and you want to stop close. You can't pull a lean cable and wait for the engine to shut down. ...
If that process really only took a half a second it may be easier to 'adjust to' as you say, but realistically shutting down in that fashion does not happen that quickly in most cases.
Consider if you will, that when you shut down your airplane, you have ground friction that has already stopped your forward momentum (you can idle without moving . . . not so with a boat), and you are usually well removed from people and any other obstacles that possibly contribute to committing a terrible OOPS.
In many cases, when docking an airboat there may be currents and/or wind to deal with and unlike your momentum, steering control stops at the same time the prop stops moving air over the rudders. Beyond that there may very well be people in a much closer proximity where a turning prop is far less desirable.
Using the mags to shut down is not only more time effective by allowing prolonged maneuverability and control when docking, but can very well be a safer alternative in many common scenarios with an airboat that you simply don't encounter with an airplane.
It sounds to me like you have about as much airplane and airport experience as I have airboat experience. Consider, if you will, not all airplanes have brakes and most will roll on concrete (even on grass) if simply left to idle without chalking a wheel or setting a brake. I have flown many aircraft that would not sit still at idle. None of the six aircraft I fly here will sit still at idle on concrete. Only about half of them will sit still on the grass if it hasn't rained in a while (idle ranges between 500 and 700 rpm, one Cessna will idle at 400) I once saw an airplane start to roll after few minutes at idle. The pilot started it to go fly then decided to leave it running while he went into the office "for a minute".Deano wrote:If that process really only took a half a second it may be easier to 'adjust to' as you say, but realistically shutting down in that fashion does not happen that quickly in most cases.
Consider if you will, that when you shut down your airplane, you have ground friction that has already stopped your forward momentum (you can idle without moving . . . not so with a boat), and you are usually well removed from people and any other obstacles that possibly contribute to committing a terrible OOPS.![]()
On the flip side, I do have quite a bit of boating experience and outboards are easier than airplanes. Current and wind are the same for all boats. Outboards just give you reverse to use if you come in too fast or miss your target but I have been seeing some talk and pictures about airboats with brakes, powered anchors and trolling motors which would be of great use in tight areas.
Most of the time, if an aircraft engine will not shut off immediately when the mixture is pulled, there is something wrong with the setup. I see a lot of posts about the mixture arm tied to full rich. That is a case where I would expect the engine to run for a bit when the fuel is turned off. If you want to talk safety, lets explore how a properly set up engine without fuel cannot run while simply turning off a mag switch may or may not kill the engine due to a bad switch, bad wire or any other bad connection to the ground without any warning. Imagine the OOPS
Just my 2 cents but it seems like if a person wants to use an aircraft engine then it should be operated like one if they want the benefits of it. Treating it like a car engine is just inviting problems.
After seeing this post, I was only meaning to afford you some insight that you seemed to lack due to inexperience with an airboat, no more, no less. My bad. I was only responding to this single question you asked, not attempting to engage in a debate about the thread's contents.Planeguy wrote: I am not really an airboater yet but can that extra half second at idle really be that big of a deal? It seems to be it wouldn't be hard to get use to.
Until you stated as much, I had no means of knowing that you had quite a bit of outboard experience and had been 'reading about and looking at pictures of airboats with brakes, powered anchors and trolling motors.' You'll have it all figured out in no time. Obviously you are already well versed in shutting down your engine.
Have a nice weekend.
Deano.. Your input is much appreciated. Only by reading posts like yours can I gain the understanding and knowledge I need. There are a few things I can't understand, like why anyone would tie the mixture lever open on an aircraft carb or throttle servo then install a separate shutoff in line and complain it won't shut down immediately when the fuel is shut off. Maybe most complaints are coming from people who have installed automotive carbs on aircraft engines. There is just so much I do not know and that lack of understanding is what prompted the question you responded to. I probably should have phrased my question more along those lines but some of it is just occurring to me as I type this.
- trailerdon
- Site Supporter - IV
skip the 93 and go straight to av gas. Problem solved !
I just wanted to bring this thread to a close by reporting that switching to 93 octane I have solved my problem. I have run at least 8 tanks of 93 octane through my motor and is ready to stop now when I am! Thanks for the expertise and input from this site to solving my problem!
slow the idle speed down to 500 or less this will help. if the idle is up over a 1000 they want to run on. I have this engine in my plain and always pull the mixture to full lean and engine back to idle and it cut off
What part number, brand, size is the electric fuel solenoid shut off that Schmitt was talking about?
I honestly and truly love all the guys that start their engines on both mags and use only the mags to shut'em down....it keeps my little mag repair shop busy...lol
