Spacer motor.
twister69z
Spacer motor.
Post by twister69z » Fri Jun 17, 2016 2:21 pm
Can someone post a picture of the crankcase /cylinder on spacer motor for Lycoming?
Twister69z
mwood7800
Re: Spacer motor.
Post by mwood7800 » Sat Jun 18, 2016 7:37 am
Are you looking for a pic of the aluminum plate between the cyl and case?
twister69z
Re: Spacer motor.
Post by twister69z » Sat Jun 18, 2016 2:55 pm
Yes would like to know what hardware is used , studs changed ect.
Twister69z
chugalug
Re: Spacer motor.
Post by chugalug » Sun Jun 19, 2016 4:07 pm
If it's a case that used cyl. hold down plates the studs will be long enough, because you don't use hold down plates. The cyls. will have to be cut on the barrel so the cyl nuts sit flat on the cyl. flange, I can't of what that cut is called. Some 480 cyl. are cut some are not. Some use PE 150 shroud tubes, myself I use Lyc. A/V tubes don't know the part # 540 AV tubes are too long, 480's too short but some are just rite, you'll have to dig through your parts.
krazymatt
Re: Spacer motor.
Post by krazymatt » Sun Jun 19, 2016 8:40 pm
Why not just run high compression pistons
chugalug
Re: Spacer motor.
Post by chugalug » Mon Jun 20, 2016 2:26 pm
krazymatt wrote:Why not just run high compression pistons
What piston r u going to use in a long jug A/V cyl.?
JT540
Re: Spacer motor.
Post by JT540 » Mon Jun 20, 2016 4:28 pm
they make 10 to 1 11 to 1 and 12 to 1 pistons for av 540 360 with long barrels. performance engines out of California has some real nice ones
twister69z
Re: Spacer motor.
Post by twister69z » Thu Jun 23, 2016 1:56 pm
Wow , asked a simple favor , a PICTURE of the spacer and hardware. Now we are talking about Pistons....
Twister69z
Re: Spacer motor.
Post by Deano » Thu Jun 23, 2016 2:28 pm
Twister, When this had been here two or three days and you had no response to your request, I searched diligently to try and find you that picture because I swear I remember seeing one and it would've had to have been here. :dontknow:
Anyway I was not able to find one and I can assure you it wasn't for lack of trying. You have been a big help to many others in addition to myself. I was hoping to find said picture for a little payback, but alas, it was not meant to be. If I do find one, you'll be the first to know.
JT540
Re: Spacer motor.
Post by JT540 » Thu Jun 23, 2016 3:34 pm
twister69z wrote:Wow , asked a simple favor , a PICTURE of the spacer and hardware. Now we are talking about Pistons....
Twister69z
lol mike I was just answering the guys question. I can send you one if you want, I have a left over one from a build.. or I can just email you a pick of it off the motor
Re: Spacer motor.
Post by kwanjangnihm » Thu Jun 23, 2016 4:28 pm
Deano wrote: I searched diligently to try and find you that picture because I swear I remember seeing one and it would've had to have been here
Deano I was thinking the same thing. I may have been thrown off by bobby jr's short jug 540 pics in his gallery.
Justin post the photos so we can check the setup out, or explain what each setup will do. (spacer or short jug 540)
:thumbleft: :rebel:
HAMMERHEAD
Re: Spacer motor.
Post by HAMMERHEAD » Fri Jun 24, 2016 12:14 am
Here you go
B-White
Re: Spacer motor.
Post by B-White » Fri Jun 24, 2016 6:34 am
Aluminum rods....wheww,must be nice!!
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
twister69z
Re: Spacer motor.
Post by twister69z » Fri Jun 24, 2016 11:13 am
Thanks for the picture, now I get the picture ! Was wondering just how they put a spacer in and was able to seal the flange. Thanks again!
Twister69z
goldhunter_2
Re: Spacer motor.
Post by goldhunter_2 » Fri Jun 24, 2016 11:49 am
I don't know if you can see it in this old plate picture, but the inside of plates should have bevel cut just like case and cylinder for Orings to make the seal
:rebel:
