Oil pump o-ring
- Southern Airboat Member
Oil pump o-ring
Anyone have a part# for the o-ring on backside of the oil pump on a 0320 h2ad & where I might could order 1 thanks
Re: Oil pump o-ring
http://www.southernairboat.com/pdf/airc ... /lycoming/
look up your motor. the size is usually listed or called out for the orings. once you know the size you can order it anywhere. McMaster, miller bearing, central hydraulic...
Re: Oil pump o-ring
Tried ordering from couple places...30 business days to ship lol..I believe I've tried to find it here in town once before but can't remember..
Re: Oil pump o-ring
Lycoming part # LW15070 3 1/2 x 7/64
You might try and call Tom Schmidt, looks like he's had them in the past.
Schmidt Aviation Inc.
Ft Lauderdale, Fl 33309
954-772-0772
If not, these guys claim 2-3 days . . .
http://www.aircraft-specialties.com/o-r ... -lw-15070/
954-772-0772
Re: Oil pump o-ring
Ok I'll try Schmidt..thanks..
Re: Oil pump o-ring
Well hate to say Lycoming specs r wrong..pulled oil pump off & measured o-ring id & it's not 3.50 it's 3.75..so thought maybe o-ring was outta whack & measured pump where o-ring goes & it's 3.75 Id,i found a 3.50..that wouldn't even come close to working
Re: Oil pump o-ring
Just talked to Schmidt & sure enough he measured 1 & it's 3.73 id & not 3.50 as the manual & websites are advertising
Re: Oil pump o-ring
Thanks for the replies and help
Re: Oil pump o-ring
Wow, had no way of anticipating that.
Sure glad you didn't order one and then find that out 34 days later.
So, was Tom able to hook you up or are you still needing one?
Re: Oil pump o-ring
Yeah gonna order 1 probably monday
Re: Oil pump o-ring
For what it's worth, what you need looks to be dash240 which is Grainger's item number 41UM76.
They don't have them in Ocala, but claim a fat week to get them. The 5 pack is < Lycoming's single price.
There used to be one in W Melbourne, although I don't know that it's still there. Maybe they have them?
https://www.grainger.com/product/GRAING ... ing-41UM76
Re: Oil pump o-ring
Hmm..I called Granger yesterday morning & spoke to a lady in sales department & she couldn't find anything that size
Re: Oil pump o-ring
That part # spec says 1/8th diameter not sure if that would b too thick or not compared to 7/64..b worth looking into tho
Re: Oil pump o-ring
I wouldn't think 15 thousandths would be a deal breaker in 4 inches.
But then I don't have mine apart to look at it either.
Re: Oil pump o-ring
Yeah I was thinking same thing Deano thanks
Re: Oil pump o-ring
If you are thinking the size can be fudged a little, you might try part number MS28775-240 (1/8 x 3.75 x 4). I haven't checked but I would think an auto parts or hydraulic shop would be able to match that up otherwise it's ~$1.25 plus shipping from aircraft vendors and should be readily available.
Re: Oil pump o-ring
You are wasting your time talking to the people who work the counter at Grainger. Get the book or look up on line.diamondback0320 wrote:Hmm..I called Granger yesterday morning & spoke to a lady in sales department & she couldn't find anything that size
