Fuel Pump
Monkeydust
Fuel Pump
Post by Monkeydust »
Been reading on here. I have a pe90/520 conv.Going to replace the mechanical fuel pump.My question is wich would be better,original replacement or dodge slant 6 pump like I read about on here.Thanks
jeepinocala1111
Re: Fuel Pump
Post by jeepinocala1111 »
Monkeydust wrote:Been reading on here. I have a pe90/520 conv.Going to replace the mechanical fuel pump.My question is wich would be better,original replacement or dodge slant 6 pump like I read about on here.Thanks
Dodge work perfect and is very cheap with a warranty. :cheers:
goldhunter_2
Re: Fuel Pump
Post by goldhunter_2 »
Give the choice, I'd personally want the original replacement , however the slant 6 is easy to find and works or just run a elec pump if you dare
:rebel:
Monkeydust
Re: Fuel Pump
Thanks for the info.I think ill stay with original replacement.
lorick
Re: Fuel Pump
Post by lorick »
If you buy the dodge one buy 2 you'll need it.
