Part number for starter
littlebigswole
Post by littlebigswole »
Does any one know a part number for the Toyota starter conversion. My starter has no numbers on it
Cherpa
Re: Part number for starter
Post by Cherpa »
What motor ?
We grow too soon old and too late smart.
mojoe
Post by mojoe »
Mark 7:9
Cherpa
Post by Cherpa »
This is a NAPA part number 244-4891. This fits my Lycoming 0-360. Just check the nose gear, you may have to change it out.
littlebigswole
It's a 0320 narrow deck
Post by John Fenner »
All depends on the mounting boss location, if the holes are directly across the pinion shaft then it is an innovative accessories type or Norman Clay kit, if the holes are offset from pinion it is an air tec kit which is an 84 Supra turbo.
deepsea diver
Post by deepsea diver »
It depends on the starter mount. Is it an DICK Waters air tech or a Norman Clay mount.
Then you need to know is it 11 or nine tooth . Your local started/alternator shop can rebuild it for about
$100.00. Post a pick of the starter and mount. Dick or Norman will ship out quick. The starter shop on Forsyth road in Orlando change the gear out on mine in five minutes. Air tec , Dick Waters has a web site, take a look. It's a rice burner starter, Nippon densco. If the starter mount has a back up flange that supports the alum mount flange of the starter(slip on and uses the 2 large bolts to hold it in place,most likely Air tec)
Densco number 19093a is 11 tooth starter
19094 is 9 tooth starter
deepsea diver
19094 9 tooth
Look in recent photos or my gallery, there is 11 tooth started parts ref numbers!!!
deepsea diver
Can somebody post the pic into thread., v/r DSD
flcracker9
Post by flcracker9 »
If yours is the offset style (starter gear off center of the mounting bolts), I have a fairly new one (started the boat 3 times, then the air tech bracket broke) that I'd be willing to sell you? I replaced it with the Innovative setup so I no longer need it. PM me if you're interested.
Kevin
littlebigswole
Disregard
dblj006
Post by dblj006 »
deepsea diver wrote:It depends on the starter mount. Is it an DICK Waters air tech or a Norman Clay mount.
:D :D :D
Broke.
apg1387
Post by apg1387 »
I have an Norman clay and adaptor and what looks to be an 11 tooth from Napa but I can't read the part number its too faded and its a little tricky to see around that cone piece. Can you tell what starter I need from these pics.
SeatCover
Post by SeatCover »
I run a toyota cressida starter, it is bigger than the one I replaced, I think from a celica? The bigger (longer) starter is definitely better. Bring your old one to napa and have em pull a few off the shelf, you will know what ya need. Stay away from the cheapos at advance or discount, unless your boat hand props easy.
apg1387 wrote:I have an Norman clay and adaptor and what looks to be an 11 tooth from Napa but I can't read the part number its too faded and its a little tricky to see around that cone piece. Can you tell what starter I need from these pics.
This is a Chrysler starter adapter with a late model dodge magnum starter.
jopete
Post by jopete »
I couldn't find a part # on my starter, so I just went to town and got it rebuilt for about $100. works like a champ now.
of course, I found the new replacement starter I got several years ago and forgot that I had bought it. lol was sitting next to the new replacement mag and alt I keep in the closet.
Post by Slidin Gator »
jopete wrote:I couldn't find a part # on my starter, so I just went to town and got it rebuilt for about $100. works like a champ now.
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
That's the kinda stuff I do!
Any chance you found my meat grinder in your closet? Just how in the hell did I loose a damn electric meat grinder since last season? In order to find it, I'm gonna have to go buy a new one :violent1:
slaughter
Post by slaughter »
Who makes this kit. “Starter” 9 Thoth
[attachment=1]F0BBC1E1-382A-4744-922F-D365FAD0BE5F.
Schmidt Aviation in Ft. Lauderdale is one source, $195 new the last time I bought one.
deepsea diver wrote:Densco number 19093a is 11 tooth starter
19094 9 tooth
https://dnlauto.com/product/airboat-sta ... oth-19094/
https://www.amazon.com/AIRBOAT-STARTER- ... B008XOJFV0
Pricing depends on your need at the time.
