av200 build
pilgrim1112
av200 build
Post by pilgrim1112 » Tue Aug 23, 2016 9:59 pm
ok guys ive got my av200 off the boat and gonna tear it down to go through and paint to match the boat. Was wondering since I'm goin in was thinking about new 10:1 or 12:1 what are your guys suggestions. its is a stock av 200 with updraft 4-5 carb now and any recommendations for possible cam?? but don't know which one ive read 290 grind but hey idk that's why I'm asking. is it worth me to do all this and if so what kinda numbers do you think ill see after also since ill have cylinders off should I bore or no theres nothing wrong with it just tearing down to paint and go through
jeepinocala1111
Re: av200 build
Post by jeepinocala1111 » Wed Aug 24, 2016 7:08 am
pilgrim1112 wrote:ok guys ive got my av200 off the boat and gonna tear it down to go through and paint to match the boat. Was wondering since I'm goin in was thinking about new 10:1 or 12:1 what are your guys suggestions. its is a stock av 200 with updraft 4-5 carb now and any recommendations for possible cam?? but don't know which one ive read 290 grind but hey idk that's why I'm asking. is it worth me to do all this and if so what kinda numbers do you think ill see after also since ill have cylinders off should I bore or no theres nothing wrong with it just tearing down to paint and go through
If that is a 0-200 very much like the pe-90 then my opinion is get some large cylinders I have seen the pe90 with 470 cylinders kick butt.
Outlawaircraftengines
Re: av200 build
Post by Outlawaircraftengines » Wed Aug 24, 2016 8:41 am
give me a ring buddy. I have pistons, custom cam grinds, ect. All the stuff you need and can also do the jug overhauls for you. 863-698-0383
Gary Barber
Outlaw Aircraft Engines
www.outlawaircraftengines.com
863-698-0383
diamondback0320
Re: av200 build
Post by diamondback0320 » Wed Aug 24, 2016 10:09 am
it says av 200 not 0-200!
Skeeter-Gee
Re: av200 build
Post by Skeeter-Gee » Wed Aug 24, 2016 3:03 pm
Hey gary do you have any 180 nd cylinders ready to go ? if so how much , i got a leaky exhaust valve or seat on #1
pirate
Re: av200 build
Post by pirate » Wed Aug 24, 2016 5:28 pm
What the heck is an av 200?
Is that an angle valve IO/O/360?
A lot of folks assume that because it has angle valves and is 360 CID means it develops 200 hp. Many only develop 180 hp and a couple, less. That being said, 10:1 pistons work just fine but you need to run av gas. Jr. Jurnigan can get an experimental Lycoming grind cam that along with the pistons should bump the hp to around 220, but they're pricey.
pilgrim1112
Re: av200 build
Post by pilgrim1112 » Wed Aug 24, 2016 7:50 pm
thx for the replys guys gary ill prolly call you tomorrow sometime. it is an angle valve 0360 with a ma4-5 so that makes it around 190 hp now just want to get a lil more out of it that's all nothing crazy so ill prolly go with the 290 grind cam and 10:5 - 1 pistons if I can get a good deal and I guess ill have to change the main jet in carb as well but well see
GMAC 76
Re: av200 build
Post by GMAC 76 » Wed Aug 24, 2016 8:21 pm
if your carb is an MA-4-5 off an 0-360/180hp a really good main nozzle change for the AV 200 is the 47-725 from the 210hp franklin carb
billybob
Re: av200 build
Post by billybob » Thu Aug 25, 2016 10:50 am
I'm not sure if they are still in the classifieds but a fella had 4 11487's for sale. New.
I do all my own stunts!!!!!!
Walter Sobchak
Re: av200 build
Post by Walter Sobchak » Thu Aug 25, 2016 11:50 am
WTF Donny?!
