my 220 gpu conversion
slidingforhogs
Post by slidingforhogs »
Ok guys here's my delima, have a 220 that was fresh out of a gen , it has the 878 cam in it .. I put on a set of e225 cyls with pop up 4 ring pistons . before I changed it up i could only turn my prop 72/32 wood paddle nomore than 2500 . after the conversion it only gained 100 rpm . was found it want getting enuff intake air , so changed that and removed to holly 2 barrel carbon and replaced it with a 4 barrel carb, with only a minimal gain . again no great topend near the 3000 mk in seeking. Mg was also retired and set properly . starts right up . could there be a possibility that perhaps the exhaust could be choking it down? It has same headers that was on 220 cyls. Do they make a larger diameter tube headers ? If that could be the problem. Also replaced fuel pump putting 7psi to carb recommended. What else could be the culprit? I know its alto of questions but someone should know the possible fix.... Thanks mike
11'7 gore ,
220 gpu swinging a woody...
Stomp on it!!!!
Re: my 220 gpu conversion
Post by John Fenner »
Well, to be honest, you gained 100 rpm, but it should snap to that much harder than before, what size 4v did you put on it?
Post by kwanjangnihm »
I have always read that a stock GPU cam was designed to NOT turn more than 2600 rpm.
Is the cam holding you back?? :scratch:
slidingforhogs
650 carbon , was told the 868 cam is the best cam for that engine , had others before and they turned it to 3k,
11'7 gore ,
Stomp on it!!!!
650 cfm is a bit too big, what do you have the timing set at?
Also, do a wide open throttle pull, with very little to no idle time with engine hot, shut it off and pull top plugs, should be tan on insulator.
slidingforhogs
30dgree timing
11'7 gore ,
Stomp on it!!!!
Was it WT Dave who was having a airboat cam and spring upgrade kit produced for the GP users ?
I recall something about that
30* is too high for the pop-up piston as well too high for dished pistons, set timing to 23*
slidingforhogs
Another question.. Has anyone cotton a wood prop and it not be the pitch that is stamped on it? Mine says 72lxl32g .. Its sensenich paddle.. I've had other 220s before stock that turned paddle props 3k with the same stamp before... :scratch:
11'7 gore ,
Stomp on it!!!!
I wouldn't recommend any paddle prop on any 220 Crank, a 2 blade Whirlwind stump puller is great on a gpu.
jeepinocala1111
Post by jeepinocala1111 »
A holley 500 2 barrel is the carb you should be running a 4 barrel will not work as good.
jeepinocala1111 wrote:A holley 500 2 barrel is the carb you should be running a 4 barrel will not work as good.
Exactly, should have #75/6 jets, power valve plug off, and 22*/23* of timing.
