O-540 mags have no kill switch wires
jakerat87
Post by jakerat87 »
I recently bought an o540 straight valve engine that was a direct take off engine out of a plane. My mags dont have wires for kill switch. Could anyone explain how to wire them? There are two holes in the points caps labeled switch and retard. When i take that cap off there is a wire going to the hole thats labeled switch that looks like a plug socket of some sort. Is there a connector i can buy that will plug into that hole and thread on...? Need help thanks.
twister69z
Re: O-540 mags have no kill switch wires
Post by twister69z »
See those holes in the small cap on the mag? Those are where "p" leads with special terminals are inserted and threaded on to the cap. If the part number of your magnetos designates the left magneto as a shower of sparks mag it will need two leads , one for the "l p"lead the other for the shower of sparks lead.
Twister69z
Post by John Fenner »
It also appears that the left mag used the retard for startup, I'd suggest pulling it and installing an impulse coupler and pins, then omit the right hand set of points.
schmidtav2
Site Supporter - VII
Post by schmidtav2 »
We have the P-lead kits for these mags and I agree with John, you should convert the left mag over to an impulse mag. We can handle this for you also if you want.
Schmidt Aviation
954-772-0772
jakerat87
Post by jakerat87 »
Ok where are you located schmidt aviation?
mojoe
Post by mojoe »
John Fenner wrote:It also appears that the left mag used the retard for startup, I'd suggest pulling it and installing an impulse coupler and pins, then omit the right hand set of points.
How can you tell?
Mark 7:9
P-lead plug and cap for retard port gone, the harnesses stay with the airframe, no reason to remove cap otherwise.
