gpu 220
cowmanhutch
gpu 220
Post by cowmanhutch »
Hey all.
I have been running my boat this fall up here in South Dakota and need a little help.
I bought this boat used and have no history on engine.She is burning through oil at 3 to 4 its per tank full. I know these engines burn oil but this seems excessive.My question is....Is there anyone up here in midwest that can do a to end rebuild that you all know?
What are prices for total rebuild? Being up here in South Dakota I have no idea about a gpu rebuild.
Thanks
fletchster76
Re: gpu 220
Post by fletchster76 »
That's a lot of oil but not unheard of on a gpu. That motor is just a non-flying aircraft engine so anyone that has ever done a top end on an aircraft engine can do it. Super simple job. Ducurra aviation will have all the parts necessary. No idea on price up there but it's probably a little more than a half day job (full day if you've never done one) for just rings and seals.
http://www.ducarraaviation.com/
14’ Viking, 520 conversion, 72" 3 blade ngh
jeepinocala1111
Re: gpu 220
Post by jeepinocala1111 »
What oil are you running?
cowmanhutch
Re: gpu 220
Thanks for the replys... running XC 20/50
twister69z
Re: gpu 220
Post by twister69z »
Is most going out the breather vent? My I suggest a air oil separator to " recycle " the oil going out the vent? They do cut the bleeding down considerably. Also when topping the cylinders make sure to switch to 4 ring Pistons you will then have a "dry" engine?
Twister69z
schmidtav2
Site Supporter - VII
Re: gpu 220
Post by schmidtav2 »
as Twister69 said if you have oil coming out of the breather, which is not uncommon on GPU engines, I would suggest an air/oil separator as well, we do have them custom made if you want one.
Schmidt Airboats
Pompano Beach, Fl
954-782-2845
jeepinocala1111
Re: gpu 220
cowmanhutch wrote:Thanks for the replys... running XC 20/50
Try running this oil. And do the breather tube mod. I also ran an oil additive lucas oil stabilizer it helped a lot for my old gpu.
AeroShell Oil 100 SAE Grade 50 Straight Mineral Aircraft Oil
glades cat
Re: gpu 220
Post by glades cat »
ID which cyls are burning oil and replace them. Those gpu's will run fine with good cyls.
cowmanhutch
Re: gpu 220
Right on...Thank you all so much! We run on shallow White River hunting beaver at night.
Has a Combee hull with an 6 blade prop.I usually have 3 other guys with me hunting and I can't believe how much it weight it can carry and still handle good.
I'm a nube at airboats so thanks again for helping me.
Re: gpu 220
Post by kwanjangnihm »
cowmanhutch wrote: hunting beaver at night
:cheers: :cheers: :cheers: :cheers: :cheers:
cowmanhutch
Re: gpu 220
Haha.... yea I got it... lol.
jeepinocala1111
Re: gpu 220
cowmanhutch wrote:Right on...Thank you all so much! We run on shallow White River hunting beaver at night.
I usually just use my truck when hunting beaver at night :scratch:
12PSI
Re: gpu 220
Post by 12PSI »
I don't have to hunt beaver anymore, it hunts me!
